Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - procomp connecting rods and cranks
Old 05-12-2013, 07:41 PM
daveclap50 daveclap50 is offline
thanks again bob, its funny since i was more than likely going to get a set of probe pistons to go along with the budget theme i have a set of 990s that ive already rebuilt and my top end will be a edelbrock rpm airgap and a holley 850 dp probably going with a mild marine grind from comp so i can get a flatter torque curve already have the top end just have to buy the pistons and crank since i found the rods on craigslist back in january, if you have a suggestion on what cam i should run im all ears
