Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Proportion Valve question.
Old 01-05-2019, 08:00 AM
joe_padavano joe_padavano is offline
Old(s) Fart
Last wiki edit: Wheelbase database
Originally Posted by Bob37pont View Post
When I check/push the reset on the prop valve there is a bit of fluid that leaks out. Is this normal?
Movement on the reset button is only about 1/16".
No. The o-ring that seals that button is apparently bad.
The Following User Says Thank You to joe_padavano For This Useful Post:
Bob37pont (01-05-2019)
