Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Proportion Valve question.
Old 01-06-2019, 01:39 PM
joe_padavano joe_padavano is offline
Old(s) Fart
Last wiki edit: Wheelbase database
Originally Posted by Bob37pont View Post
Shouldn't the push on contact post between the two inlets go to ground (electrically) when the brakes are pressurized?
No. It's a differential pressure switch. It only makes contact if you loose pressure on one side of the brake system and the internal piston is forced all the way to one side.
