Proportion Valve question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2019, 05:04 AM
Bob37pont's Avatar
Curmudgeon at Large
Question Proportion Valve question.
When I check/push the reset on the prop valve there is a bit of fluid that leaks out. Is this normal?
Movement on the reset button is only about 1/16".
Old 01-05-2019, 08:00 AM
Old(s) Fart
Last wiki edit: Wheelbase database
No. The o-ring that seals that button is apparently bad.
The Following User Says Thank You to joe_padavano For This Useful Post:
Bob37pont (01-05-2019)
Old 01-05-2019, 01:14 PM
Bob37pont's Avatar
Curmudgeon at Large
Thanks Joe.
Old 01-06-2019, 01:37 PM
Bob37pont's Avatar
Curmudgeon at Large
And additionally...
Shouldn't the push on contact post between the two inlets go to ground (electrically) when the brakes are pressurized?
Old 01-06-2019, 01:39 PM
Old(s) Fart
No. It's a differential pressure switch. It only makes contact if you loose pressure on one side of the brake system and the internal piston is forced all the way to one side.
Old 01-06-2019, 01:42 PM
Bob37pont's Avatar
Curmudgeon at Large
Oh, so it would be a brake failure indicator. Got, thanks again Joe.
77 chevy truck no rear brakes bad proportion valve? bigals77 Suspension - Brakes - Steering 3 09-13-2011 08:26 AM
Can I use a truck proportion value and my car. oldtimercarnut Suspension - Brakes - Steering 2 07-04-2011 05:37 PM
proportion valve 57chev Suspension - Brakes - Steering 4 08-30-2007 07:13 PM
brake proportion valves Mr. Wormy Suspension - Brakes - Steering 6 10-08-2006 10:47 AM
brake proportion valves hotrod389 Suspension - Brakes - Steering 2 04-19-2006 10:45 AM
