proportioning valve issue/mystery - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-14-2019, 03:55 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Sorta following this thread but I'm starting to wonder if you have either the wrong pedal ratio, a very small bore MC, too much clearance on the pads/rotors shoes/drums, or the calipers are flexing or something along all those lines. Perhaps a combo of all of those.
  #47 (permalink)
Old 04-14-2019, 11:14 PM
tell me if im wrong but pedal ration wont decrease/ increase brake fluid pressure ?
about the master cylinder i have a 1 inch bore , i tried a 1-1/8 and it was wosre
with 1-1/8 yes hard pedal but almost nothing at the calipers
i adjusted the rrear drum pretty closed to the drum ( they drag) just to make sure . and basicly only the rear is working
calipers flexing? everything is new
and i did a pressure with caliper out of there braket. i could not install the pressure gages while there are mounted. just to say pressure its pretty low out of there braket wich i think avoid the flexing
also the front pads drag a little , i dont think there is clearance issue
everything is news . rotor , pads , line , hoses etc...
  #48 (permalink)
Old 04-15-2019, 07:02 AM
55 Tony's Avatar
As for pedal ratio, yes and no. If your ratio is high, the pedal will be easier to press BUT it will not move as much fluid. If your ratio is low, the pedal will be harder but the same amount of movement will move more fluid. So if you press on the pedal with the SAME amount of pressure, the high ratio will give you more pressure than the low ratio, but it may not move enough fluid.
It is a kind of balancing act you have to learn when customizing brakes.
As far a calipers flexing, to tell you the truth I sometimes wonder if mine flex a little more than they should. That is something that doesn't matter if it's new. What matters is who made the calipers and how strong did they make them.
Young enough to learn ... too old to remember.
  #49 (permalink)
Old 04-20-2019, 05:46 PM
well today i did few experiment again
i had 4:1 pedal ratio
i drilled a hole and went to 3:1
yes engine off pedal get harder
but engine 'on' nothing changed still pedal going down and no much breaks..
all break come from the rear i got almost nothing at the front
i even swap master cylinder one more time just " in case " to a 1 1/8
its even worse...front grab nothing
I did the test with the rear plugged at the master cylinder.. only kept had the front line hooked up at the mastrer cylinder
  #50 (permalink)
Old 04-20-2019, 05:50 PM
55 Tony's Avatar
I think I asked before, can you show us pictures of the master cylinder and proportioning valve? Also pictures of the calipers showing the hose and bleeder.
  #51 (permalink)
Old 04-20-2019, 09:54 PM
Here you can see last test with only the front line hooked up
ID:	442535   Click image for larger version
ID:	442537   Click image for larger version
  #52 (permalink)
Old 04-21-2019, 06:52 AM
55 Tony's Avatar
Can you possibly put shop air pressure into the calipers? No, that low pressure won't stop the car, but it should be a decent amount of resistance when trying to spin the wheel.
Before I get yelled at, yes this could introduce a small amount of moisture into the system, but with all the bleeding going on, you can always bleed a little more.
  #53 (permalink)
Old 04-21-2019, 10:56 PM
with the car on jacks
and someone pressings on the breaks engine off , the front wheels stops
i also look for any flex from the caliper engine on. and nothing
should metric caliper move a little or no?
  #54 (permalink)
Old 04-22-2019, 06:29 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Is that a single piston caliper, who's brake kit are you using? Would like to view the parts, my un-expert opinion at the moment is telling me they are not up to the j O B.
The only flex and it is not a flex, it is simply a caliper centering itself, too the rotor and for the most part, only happens after pads are swapped.
If you have a link to the source of the parts used please provide... Think that could be helpful to all.
Pep
The Following User Says Thank You to rip-tide For This Useful Post:
Vincentnova (04-23-2019)
  #55 (permalink)
Old 04-22-2019, 06:56 AM
55 Tony's Avatar
Rip, I think the calipers do actually flex *open* a bit normally. With over 1000 psi x the square inches of surface area of the caliper cylinder, that's a lot of pressure. But forget that for now because ...
I caught something I don't recall reading before. Back in post #45, he said they are POWER brakes. That changes everything! It didn't even click when I saw the picture of the master cylinder with the booster behind it. Gawd I feel foolish going this long without asking that.
Some people change the pedal ratio lower to get less travel in the pedal with power brakes. But I don't think his booster is working so that would result in a very hard pedal with less braking then he has now.
So Nova, what size vacuum booster do you have and how much vacuum do you have? Where is the vacuum hose hooked up? And are you using a power master cylinder? Show a pic of the back end of one of the others you tried. It should have a very shallow hole in the center of the piston. Deep hole is for manual brakes.
  #56 (permalink)
Old 04-22-2019, 09:03 AM
rip-tide's Avatar
That's a 7in booster, (small) usually for under the floor installs. Easy to troubleshoot a bad booster, apply the brake with the motor off.
Holding, start the engine the peddle will move closer to the floor if good, and NOT hit the floor. Stops about 2 inches or so..above the floor board...
Tony is on it, especially if the pedal in all the way on the floor...
If it is going to the floor here is something to look into:
There is a defined adjustment for the MC to booster actuator pin hight or length, and a tool for setting it.
Here is a picture and the instruction for usage .... mine it the 20 dollar version they sold before CNC came along LOL
Pep
ID:	442567   Click image for larger version
  #57 (permalink)
Old 04-22-2019, 12:12 PM
Bob37pont's Avatar
Curmudgeon at Large
Pep
Man that would have saved me a lot of trial & error!
At least mine is on the firewall, and the cowl support rod allowed me to hang the MC with a bungie cord when I separated it from the booster!
  #58 (permalink)
Old 04-22-2019, 12:51 PM
ericnova72's Avatar
More for Less Racer
This is just a shot in the dark...but I know many of the GM master cylinders from the late 60's up through the late 70's the front fluid cavity feeds the REAR brakes, and the rear fluid cavity feeds the FRONT brakes.
My be something to check as to why you get rear brakes with plenty of fluid but no real amount of pressure or fluid volume to the front brakes.
  #59 (permalink)
Old 04-23-2019, 01:50 AM
Pep
at first i got a kit from a seller on ebay for 1959 to 1964 impala
complet front kit with line etc .
its easy to find , cheapest complet kit on ebay
it came with a 1 inch mc ,the booster ,prpotioning valve and lines
caliper a the gm metric 2 and half inch piston
same one that you can get from a the auto parts store .
then i also tried a 1-1/8 master cylinder
and i also have a master from jeggs an other 1 inch that i also tried
with same results
  #60 (permalink)
Old 04-23-2019, 01:55 AM
i have an hard pedal when engine is off
before i had a spongy pedal even engine off
i moved from 4:1 to 3:1 pedal ratio , and now engine i get an harder pedal
but engine on still the same..pedal go low and front calipers almost grab nothing
vacum hose is connected at the intake (engine is a lq4 )
yes i use power master cylinder
and yes shallow hole behind master cylinder ( im aware about that )
pin on proportioning valve andybird Suspension - Brakes - Steering 10 04-17-2003 09:48 AM
When is a proportioning valve needed? jpd37 Suspension - Brakes - Steering 2 03-25-2003 09:42 AM
master cylinder and proportioning valve? curtisstarlight Suspension - Brakes - Steering 3 03-18-2003 09:12 AM
S-10 Proportioning Valve TurboS10 Suspension - Brakes - Steering 5 01-03-2003 10:42 AM
adjusting proportioning valve stoke46 Suspension - Brakes - Steering 2 05-06-2002 08:14 PM
