proportioning valve issue/mystery - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 04-23-2019, 01:58 AM
Originally Posted by rip-tide View Post
That's a 7in booster, (small) usually for under the floor installs. Easy to troubleshoot a bad booster, apply the brake with the motor off.
Holding, start the engine the peddle will move closer to the floor if good, and NOT hit the floor. Stops about 2 inches or so..above the floor board...
Tony is on it, especially if the pedal in all the way on the floor...
If it is going to the floor here is something to look into:
There is a defined adjustment for the MC to booster actuator pin hight or length, and a tool for setting it.
Here is a picture and the instruction for usage .... mine it the 20 dollar version they sold before CNC came along LOL
Pep
yes i got this tool as well
the rod or pin from the booster is adjusted properly
  #62 (permalink)
Old 04-24-2019, 05:12 PM
Because the situation wher im stock is
Mean problem : brake pedal goes to the floor and front caliper dont grab
-The pedal goes to floor engine on even with car on jacks ( that could remove the hypothetic idee of flexing spindke)
- caliper to braket and rotor are square
-I dont have leaks
-Master cylinder is good ( both ports plug i get an dead hard pedal with engine in)
- i get. About 1100 psi at caliper
The things that surprise me is why even a low pedal but 1100 psi caliper dont grabs?
  #63 (permalink)
Old 04-24-2019, 05:23 PM
55 Tony's Avatar
-I dont have leaks
Did you measure the pressure with the calipers in the circuit?
The pedal going to the floor while on jack stands is no different than while it's on the ground. It means nothing.
Young enough to learn ... too old to remember.
  #64 (permalink)
Old 04-24-2019, 10:02 PM
Yes pressure gage at the caliper
  #65 (permalink)
Old 04-25-2019, 04:20 AM
55 Tony's Avatar
I'll try again. Were both the calipers hooked up when you checked the pressure? Like did you put a T in the line? Or did you attach the gauge in place of the caliper?
  #66 (permalink)
Old 04-25-2019, 06:16 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Only two things make sense
1 wrong pad, the thickness, brake material
2 rotor and caliper, not a match.
Front disks should have dedicated brake lines, not T-ed, the PV has a port for each.
reference: see bottom of page
https://www.markwilliams.com/braketech.html
Pep
The Following User Says Thank You to rip-tide For This Useful Post:
55 Tony (04-25-2019)
  #67 (permalink)
Old 04-25-2019, 11:55 AM
The pressure gage was at the caliper.
I removed the bleeder nipple and connected the gage there
  #68 (permalink)
Old 04-25-2019, 12:51 PM
johnsongrass1's Avatar
Race it, Don't rice it!
and what were the pressures? all four of them.
  #69 (permalink)
Old 04-25-2019, 05:05 PM
55 Tony's Avatar
Pep
I sure can't think of anything else. Some kind of mismatch of parts at the wheels sounds like a good possibility. Nothing else makes sense.
  #70 (permalink)
Old 04-25-2019, 08:08 PM
rip-tide's Avatar
LOL, agree, it's something simple that's for sure, been on service calls customer did everything.
Machine will not start, turn on ....... and never plugged in... oops
Pep
  #71 (permalink)
Old 04-26-2019, 04:42 AM
55 Tony's Avatar
Pep
I went to my uncle's house not once, but three times to remind him that the outlet he is using is dead. I've found many machines turned off, they didn't know they had a power switch.
What do you repair Pep?
After this thread, I may take my vehicles to the shop for brakes!
Why do my posts come up double or triple spaced when I single space lines?
  #72 (permalink)
Old 04-26-2019, 06:49 AM
rip-tide's Avatar
I could write a book about that one, field service 1970-2010.
Have a natural talent in troubleshooting and repair, of many things. What I don't know, smart enough and confident in saying, do not have the answer. Will go looking further as in research, and never get answers from a cell phone.. LOL get my drift ?
Reading your post and following the logic. We would be good friends if living in the same town.
First HotRod 56 chevy, pony power, called it the half-breed, 1965
Pep
  #73 (permalink)
Old 04-26-2019, 07:24 AM
55 Tony's Avatar
Pep
Sounds like me. Well before my teens I was rewiring lamps and things. Fixing bicycles, lawn mowers ... Did a really hard to do repair on my mom's washing machine. I sometimes find myself spending too much time on something that could be bought for $1
pin on proportioning valve andybird Suspension - Brakes - Steering 10 04-17-2003 09:48 AM
When is a proportioning valve needed? jpd37 Suspension - Brakes - Steering 2 03-25-2003 09:42 AM
master cylinder and proportioning valve? curtisstarlight Suspension - Brakes - Steering 3 03-18-2003 09:12 AM
S-10 Proportioning Valve TurboS10 Suspension - Brakes - Steering 5 01-03-2003 10:42 AM
adjusting proportioning valve stoke46 Suspension - Brakes - Steering 2 05-06-2002 08:14 PM
