PTV clearance. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2019, 04:23 PM
PTV clearance.
What is the best way to check PTV clearance without solid lifters?
Old 02-17-2019, 05:07 PM
ericnova72's Avatar
More for Less Racer
Modeler's clay in the valve reliefs, place head on and use a couple of bolts to hold it on(if using a new gasket, just snug it up, don't torque it), set up your valvetrain for that cylinder and adjust lifter until the plunger is bottomed out so it can't move....rotate crankshaft two full revolutions. Pull head back off, use a razor blade to cut and section the clay so you can measure the valve imprint.
Don't use Play-Doh, it is too rubbery and springs back when squeezed and will give a false reading. Oil the surface of the clay the valve is going to contact, so it doesn't stick.
I've never done this next method, but some guys have disassembled a lifter, and shim it inside with small washers to hold the plunger up solid.
Old 02-17-2019, 08:29 PM
chasracer's Avatar
True Hotrodder
This ^^^^.
But I never put a gasket on because the new versus crushed measurement can vary a bit and I would prefer to know that I have that additional clearance. Take a stock Chevy steel shim gasket. Most of them out of the wrapper are .019 and crushed are normally .016. I have measured the crushed at .017, .015 and .016.
Old 02-18-2019, 08:03 AM
johnsongrass1's Avatar
Race it, Don't rice it!
If you preload the lifter enough it'll stack and be close enough for what your doing.
PTV Clearance checking... SCMonte Engine 5 11-15-2016 08:37 AM
How much can one degree cam retard increase intake ptv? Berres Engine 34 08-20-2011 05:50 AM
SBC Radical Cam PTV? kmkchris1 Engine 5 01-15-2008 07:32 PM
gauge clearance Chapo1 Interior 3 03-19-2003 04:42 AM
454BB and header/plug wire clearance problems vernw Engine 1 10-31-2001 09:51 PM
