Quadrajet 4MV questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2005, 07:41 AM
I have a 74 camaro, with the stock Quadrajet 4MV. Engine bored 0.020 over, mild cam, dart heads, stock intake manifold. It was stored for a long time, but ran great before it was put up. Symptoms: upon WOT heavy, sputtering bog for a second or two in duration, followed by a short but strong burst, followed by abrupt cut out, almost like you turned off the key. Let up on gas and instant recovery, but at much lower rpm. Starts great, idles great, low RPM cruising great. I got in there last night, but was afraid to remove the top plate as the bit of gasket sticking out is hard, and I don't have a replacement yet (going to buy them today. Will I find them in stock somewhere?). Checked accelerator pumps, they seem to be working ok, they squirt when you push the little lever but I am new to car carbs and have nothing to gage it to. Pulled out filter cartridge, looks clean inside, and removed that little plastic spring loaded plug in the end of it (what is that for?? just seemed like an extra restriction.) tested the fuel pump, filled half a coffee can in about three seconds, so it seems ok, but again I have no experience to draw on. Put the filter back, went for a drive. Now, the initial stumble is much shorter in duration, I'm back to chirping the tires when it shifts to second but it is still weak compared to its former self and still hits a wall and shuts off until I let up on the gas. Also, the idle is now somewhat higher, like it won't kick down. Any suggestions as to where to look first would be appreciated.
Also, while purusing the catalogs last night I noticed the replacement quads are $200 to $300 more expensive than similar edelbrock and holley models. Why is this?
Old 05-06-2005, 08:03 AM
does the carb still have a choke? Here's a website that has a good, basic chart to help diagnos it.
http://www.recarbco.com/technical/newtrouble.html
Old 05-06-2005, 08:24 AM
Yes, it still has a choke. Thanks for the link, I am going to check it out now.
Old 05-06-2005, 10:10 AM
Hippie's Avatar
Last journal entry: HEI comparison.
If it worked good before and you haven't changed anything I'd say your problem is varnish from stale gas obstructing a port somewhere in the carb. Try running some fuel treatment through it before you do anything too drastic.
Old 05-06-2005, 11:07 AM
Excellent, a cheap and easy suggestion, I wil try it tonight.
On another note, isn't that the monkees mobile as your avatar? That was pretty much the first hotrod I ever saw that really stirred my soul as a kid. What a great show that was.
anyhoo, thanks for that blast to the past
Old 05-06-2005, 11:53 AM
Hippie's Avatar
Yep, Retro Joe uses it too. Hard to believe it started life as a '67 GTO............
Old 05-07-2005, 11:47 AM
sedan delivery's Avatar
Quadra Jet
this carb has a very small float bowl. you are probably running the bowl dry. i fixed mine by installing a 1957 283 fuel injection fuel pump. produces more volume and keeps the bowl full. or before you do this you might raise the float lever. make the top of the float level or parallel with the top of the bowl.both of these have worked for me, gives you something to try.
Quadrajet choke adjustment questions MopaRV Engine 11 02-19-2013 07:27 PM
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 8 12-13-2005 02:40 PM
quadrajet questions Eric64 Engine 0 04-25-2005 06:08 PM
Quadrajet Question(s) lardmaster Engine 5 02-08-2004 05:59 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
