Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2020, 03:46 PM
Question
My project has a Mustang II front suspension. Currently, the spring ratings are 500 pounds. If I were to go with a 700 pound rating, how much do you think that would raise my suspension?
Old 01-30-2020, 04:23 PM
39 master's Avatar
Can't tell you how much it will raise the front end but the rule of thumb is to have the lower A arms level with the ground. If the A arms are level now and you need more ground clearance the only way to go is larger diameter tires to keep the front end travel as designed. Get in touch with Detroit Eaton spring, they should be able to answer your question.
The Following User Says Thank You to 39 master For This Useful Post:
V8Square (01-30-2020)
Old 01-30-2020, 04:30 PM
ericnova72's Avatar
More for Less Racer
The result will be dependent on a number of factors...the lower A-arm lever ratio( inner pivot to spring cup vs spring cup to ball joint, and overall arm length), the free length of each spring, and the weight on the front suspension to name the three I can immediately think of.
The Following User Says Thank You to ericnova72 For This Useful Post:
Old 01-30-2020, 04:35 PM
While increasing your spring rate would raise the front , it would probably adversely affect your fine quality , look into spring spacers for a small rise or different ( taller) springs ....
The Following User Says Thank You to 2old2fast For This Useful Post:
Old 01-30-2020, 09:57 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
https://www.eatondetroitspring.com/
The Following User Says Thank You to techinspector1 For This Useful Post:
V8Square (01-31-2020)
