question concerning engine dyno test - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2020, 10:30 PM
Hello, I don't know if this is a place I can ask this question. If not please tell me where to post this question please.
If I am at the right place please help me.
*have few questions.
1_My*present*situation.
*I'm trying to do an ENGINE DYNO VEHICLE EMISSION TEST.
*The ECM I am going to use is not from the vehicle which will be tested. I have an other ECM just for testing from*the same vehicle model.
*Once the*engine is installed on the dyno bench*for the engine dyno test and check for DTC I*have Crankshaft Position System Variation Not Learned(P0315) & Lost Communication With Body Control Module(U0140).
*When I*try to do the Crankshaft Position System Variation relearn, it won't work.
2_ My*questions.
1) Is there no problem for the test even I*don't do the Crankshaft Position System Variation relearn?
2) I*think that the Crankshaft Position System Variation relearn can't be performed because of the Lost Communication With Body Control Module(U0140) DTC. Is that correct?
3) Is there no problem for the test even if I have*Lost Communication With Body Control Module(U0140) DTC ?
Old 07-31-2020, 04:29 AM
64nailhead's Avatar
Why, what and huh?
Old 07-31-2020, 05:42 AM
Excellenceautosoluti's Avatar
What year, make, and model?
Looks like euro codes to me.
Old 07-31-2020, 06:22 AM
True Hotrodder
Maybe this will help you sort out the P0315 code. The missing BCM code is another issue.
https://www.obd-codes.com/p0315
Old 07-31-2020, 10:56 PM
hi, is it a question or just a comment? little confused..
Old 07-31-2020, 10:57 PM
Originally Posted by 64nailhead View Post
Why, what and huh?
Old 07-31-2020, 10:58 PM
vehicle model : Chevrolet Express Van 4500 cutaway
year : 2019
engine model : 6.0L V8 L96
I'm a really noob. What the euro codes?
Old 07-31-2020, 11:00 PM
Thank's.
So you mean the CKP no able to perform the relearn has nothing to do with the Lost Communication With Body Control Module(U0140) DTC?
Old 08-01-2020, 06:28 AM
Chevy is American. Bcm is the body control module. The engine should run without it. But it will not run without signal from crankshaft position sensor. You need to get that sorted out first.
Why is this on a dyno? It is a van motor.
Can you just put it in the van, and go to work? Or is it some special project?
Old 08-01-2020, 06:34 AM
[QUOTE=enginedynonoob;4756125
*The ECM I am going to use is not from the vehicle which will be tested. I have an other ECM just for testing from*the same vehicle model.[/QUOTE]
You need all modules hooked up correctly. You need factory programmed ECM. Not something else.
These new cars are very picky about all the modules being able to communicate with each other.
Old 08-01-2020, 06:48 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
year : 2019
Maybe I missed the information...
What country are you located in?
What emission testing standards that are applied to this vehicle?
Old 08-01-2020, 07:04 AM
True Hotrodder
Thank's.
No I don't mean anything. I said the article might help you resolve the P0315 code issue.
Old 08-01-2020, 07:06 AM
year : 2019
Sorry, didn't mean to add to the confusion. Forget about euro codes.
Where are you located?
Old 08-01-2020, 01:42 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
year : 2019
Is this a crate engine you're trying to get working? Or fixing an existing engine/vehicle?
Old 08-01-2020, 07:11 PM
A lot of these contemporary vehicles are using serialized components, switching computers from other vehicles and major parts often leads to misunderstandings that are difficult to sort out away from a dealer shop. Seems to be a plan to freeze out independent shops.
Bogie
