Rag joint with two universal joints for steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2019, 10:38 AM
Anyone notice a difference when replacing the rag joint at the power steering pump with a universal joint?
Old 03-22-2019, 10:30 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Yes. Tighter and is more sensitive.
Old 03-22-2019, 04:26 PM
1964fordtripower's Avatar
X2
Old 03-22-2019, 06:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Most power steering pumps do not have a rag joint that I know of.
Old 03-23-2019, 11:00 AM
BuzzLOL's Avatar
Cars, Trucks, Boats
With a manual steering box, may notice more vibration through the steering wheel, but a power steering box prolly isolates you from small rapid vibrations... Don't know if rag joints are even used any more...
The steering shaft on my Crown Vic uses U-joints and the shafting is actually stock in a Z shape... the shaft goes down toward the steering box, doubles back, then on forward again... looks insane...
The rag joint prolly compensates not only for angularity, but also in and out motions... so that also needs to be considered...
And, finally, rag joints work fine and last a long long time...
Old 03-25-2019, 04:14 PM
You can also get Ujoints with a vibration damper built in if needed
Replace rag joint on '75 GMC 75gmck25 Suspension - Brakes - Steering 2 02-16-2018 01:42 PM
how do I remove universal joints Neophyte Transmission - Rearend 11 02-05-2005 11:36 AM
Do I need a rag joint? americanLT1 Suspension - Brakes - Steering 5 11-02-2004 12:31 PM
rag joint hagood Suspension - Brakes - Steering 1 06-21-2004 08:21 AM
