Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rat rod weight???
Old 08-07-2005, 09:59 PM
Eric Von Zipper Eric Von Zipper is offline
Originally Posted by cboy
E Von Z,
Have you actually had it on a scale (I'm not doubting you, just a little surprised)? That's quite a bit under the numbers I've seen. Anything peculiar about your 30 that would bring it in under a ton?
Dewey
Stripped to the bones:
Rear fenders bobbed, aint found fronts I like yet, no hood, running boards, interior, ( cept seat) single layer flooring, trunk is a box with battery and thats it. Oh yeah front and rear, and port hole glass only. Doors are bare inside. Stock firewall is gone, a single sheet of 16 gage replaced it. No heater, (dont need it) nor wipers. Body has been chopped and filled, sits right on the frame(no blocking)
Heck I didnt even paint it, just primer and sealer.
I can grab the body below the truck lid and pick it up and drag it about my shop. If I yank the flattie I can drag the front around also. 3 of us pick it up now and then, just because we can. (all 3 of us are over 250 lbs)
