Re: 57 olds - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2015, 10:33 AM
m/w m/w is offline
Z 55 Camaro
Location: Guernsey Sk Canada the greatest country in the world
Re: 57 olds
One last question fellas , it's my under standing that the 57 olds has roller wheel bearings and are very expensive to buy , is there a timken style that will interchange ? If so what is it because that would make life easier . Later Bake
Old 09-07-2015, 04:50 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
front wheel bearings or rear axle bearings?
IIRC a lot of if not most GM products used Ball style roller bearings back then.
1957 oldsmobile wheel bearing | eBay
Fact is stranger than Fiction
Old 09-07-2015, 05:05 PM
m/w m/w is offline
Z 55 Camaro
Sorry about that front wheel brgs . I thought that someone might have found a cross match to tapered roller brgs .
Old 09-07-2015, 06:01 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
I remember that on my 55 Chevy, that had ball bearings, I put later (62 I think) drums on it that had the taper bearings......Maybe a similar later Olds drum would work for you.
You could get really brave and convert your system to disk brakes.....sure would stop better.....
Heres a link.... https://scarebird.com/index.php?rout...search=57+olds
Old 09-07-2015, 10:01 PM
m/w m/w is offline
Z 55 Camaro
BOP were behind chevy in up grading their steering gear but thanks
Old 09-08-2015, 09:00 PM
There is a later hub with tapered bearings that will fit. Drum brake full size GM, late 60s, early 70s
Old 09-10-2015, 07:25 AM
m/w m/w is offline
Z 55 Camaro
Thanks again i have a 67 la sabre parts car with aluminum drums on it is this the type of car you mean ? The only reason i ask is it involves a road trip and i'm off to work soon . I'm sure the aluminum drums are toast by now but no biggy . Later bake
GM Olds 8.5 10 bolt axles bent, both of them. Olds 8.5 the same as Chevy 8.5s? cletus van damme Transmission - Rearend 33 05-23-2014 01:41 PM
olds buick 231 p/s pump onto an olds v-8? fast68 Engine 3 03-04-2010 06:07 PM
71' 350 #7 olds heads on 79' 403 olds Rough-Rider Engine 5 01-22-2007 04:04 PM
50 olds rocketmanforlife Introduce Yourself 1 10-23-2004 09:04 PM
350 Olds Engine on Any Olds 7skylark6 Engine 8 12-12-2003 06:17 PM
