Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuilding a 350 into a 383 stroker. Need help on pistons and deck clearance.
  #32 (permalink)
Old 08-24-2016, 02:33 PM
jokerZ71's Avatar
jokerZ71 jokerZ71 is offline
Wrench Turner
Skip White sells a 383 rotating assembly that is probably 1 of the best deals you can find for the money & would work well for the use you state.It has decent parts & comes externally balanced with either 5.7",or,6" rods.It includes a Scat crankshaft,Scat rods,Wiseco forged pistons,King bearings.It runs just under $1000.The pistons in this kit come with a taller pin hgt that doesn't require decking to the block to get to correct stack hgt.Just a cleanup pass if needed.The forged pistons are a little overkill,but,they don't hurt anything.
The Following User Says Thank You to jokerZ71 For This Useful Post:
AutoGear (08-24-2016)
