Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuilding a 350 into a 383 stroker. Need help on pistons and deck clearance.
  #36 (permalink)
Old 08-24-2016, 10:33 PM
64nailhead's Avatar
64nailhead 64nailhead is offline
You mention your intended use is for street driving. Does this mean to car shows and cruise in's, daily seasonal driver, or year round daily driver. How many miles a year do you think?
HP all boils down to your budget. Joker can give you a recipe for a budget 355 with a set of Vortecs that will be high 3's to low 4's hundred HP. Eric and Vinnie will rattle off 383 build specs that will be another $1000 or so that will be 450-525HP.
You've already been advised to get the best heads you can afford, but some reasonably priced options are AFR, Brodix, or a set of Chad Speier worked Profilers - all can be had in the $15-1800 range. And I'm confident that there are others that can build and port a great head for similar money. If your budget is larger than that, then start looking into 18 degree heads and the power will add. And there are a ton options that are less that don't give up very much from the higher priced options. One item to definitely not compromise on is putting in a roller cam. The most economical way about this a using a roller block. But it isn't an outrageous amount of money to use a retro roller setup either.
