Reinforce fiberglass tilt frontend - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2014, 09:23 AM
Fang16's Avatar
Last journal entry: Project change
41 Willys has a tilt frontend thatís starting to crack just above the hinge points on both sides. Looks like the glass wasnít roughed up where the cracks are. Thinking I need to take a screwdriver or something and break out the glass until I get to where it has good adhesion and lay new glass along with straightening the hinge point.
Ideas, comments?
ID:	144346   Click image for larger version
ID:	144354   Click image for larger version
ID:	144362   Click image for larger version
Old 05-08-2014, 10:40 AM
BOBCRMAN@aol.com's Avatar
Break out the bad, then take a grinder or sandpaper and rough up the base material.. Grease and wax remover.. Looks like maybe the original installer didn't break the surface to remove the wax and didn't get a good bond.
Finished fiberglass has a wax added to it to keep the surface from staying tacky. The wax rises to the surface on curing and must be removed for subsequent additions of material.
The Following User Says Thank You to [email protected] For This Useful Post:
AutoGear (05-09-2014)
Old 05-08-2014, 11:55 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
36 or 40 grit rolocs to grind out quite a ways from where the cracks exist and then layers of mat and cloth to about 8-10 mm thickness. I would be out at least 6-8 inches from the crack and taper into the thickness of the hood my self.. use laminating resin for this project...
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Old 05-08-2014, 01:54 PM
ogre's Avatar
the 'Duracell Project'
Sam
as stated grind out far enough to patch it correctly and to make sure there aren't any other bonding issues
then make the repair a lot bigger and thicker than what you think you need
my preference is to use mat only, 3/4 oz mat will conform better in convoluted areas, though you will need more layers.
cut the mat into strips and tear it into 2x2, 3x3 or 4x4 pieces and overlap the pieces
6 or 7 layers of 3/4 oz mat will give you aprox a 1/4''
The Following User Says Thank You to ogre For This Useful Post:
Old 05-08-2014, 05:42 PM
NEW INTERIORS's Avatar
life is a temporary assignment
ALWAYS wipe down after grinding with acetone and before you lay up more glass... This will clean it and make it tacky again..
And never cut with scissors unless you want to see a line in your work when done... Always tear the Mat,, this will leave it looking like it was never repaired,, If done right..
I re-glassed this new floor in this t-bucket,,, No lines... Look's like it came out the mold that way...
The Following 3 Users Say Thank You to NEW INTERIORS For This Useful Post:
AutoGear (05-09-2014), charchri4 (05-10-2014), John long (05-10-2014)
Old 05-09-2014, 07:17 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
Fang,
I did something similar when I bonded mounting tabs for the ribs on my Willys 'glass tilt front. It's in my journal here: Hot Rod Photo Journal - steve392's Journal
Take a look at entries #151 and #152.I used multiple layers of mat, overlapping each layer with a larger piece. Not exactly your situation, but the idea is the same.
Steve
The Following User Says Thank You to steve392 For This Useful Post:
Old 05-10-2014, 08:25 PM
charchri4's Avatar
Jim Stainer
I have have laid up a truck load of glass and never heard this before. THANK YOU!!!
The Following User Says Thank You to charchri4 For This Useful Post:
NEW INTERIORS (05-10-2014)
Old 05-10-2014, 09:19 PM
I see a lot of people doing fiber glass that don't know about this... If you make a repair like I said and do it right,,, Know one will ever know you did it...
It is good to know when laying up a big part in a mold... You can do haft today and the other haft a day or so later.. The key when stopping in a mold is to make sure what ever you have that is wet,, Make sure you wet it out to the tips of the mat that is down,,, You don't want to leave any tips not wet out...
I learned a lot when I hand made this car... My very first time using fiber glass after my friend showed me about glass... First thing I ever made,,, NO MOLD..
Now that I know how to use glass,, I can make anything I can think of... Very fun stuff once you know..
ID:	145170   Click image for larger version
Old 05-11-2014, 05:42 AM
Wow! I can't even imagine how awesome that would have been if you used Carbon fiber instead of fiberglass!
Old 05-11-2014, 01:49 PM
Never was into carbon fiber...
Old 05-12-2014, 05:48 AM
Last journal entry: 50 Ply wagon
I have taken 1/8" aluminum pieces and glassed them into places where stress cracks could happen. Also using layered aluminum in areas where bolts must pass thru helps with tightening without cracking the glass.
Old 05-12-2014, 07:24 AM
Now THAT would be cool.
51 Chevy Truck Tilt Frontend 51Panel Body - Exterior 14 07-28-2007 10:34 AM
56 panel tilt frontend hwyhog Body - Exterior 1 03-13-2006 09:19 PM
tilt frontend hwyhog Body - Exterior 1 03-13-2006 09:17 PM
39 Chevy Pu Tilt Frontend TOMMYDALE Introduce Yourself 4 01-22-2006 09:55 PM
Looking for a fiberglass tilt frontend for my 65 Impala Impala Freak Body - Exterior 1 01-14-2006 08:51 AM
