Removing pain in the *** a/c pump from 90ish chev truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2003, 02:52 PM
banned
Post Removing pain in the *** a/c pump from 90ish chev truck
Yeah so I finally got the freaking thing unbolted, and me not sleeping I didn't think for the longest time that I don't have to get the serpentine belt off over the lip on the ac pump, i just need to slip it off the self tensioner I'm dumb
Anyhow, I got 2 questions, first off how do I know when I have completely drained the a/c of the R-12? Secondly, I had to make a slight dimple in the valve cover for a bolt to clear (and frustration too) anyhow, this truck engine is the fuel inject TBI with the ribbed valve covers and the dimple simply removed 2 of the ribbes and pushed it down half of one. It is right on the end so I don't think the rocker will hit, I even unplugged the primary and turned it over to see, but there was no loud sound. Instead a slight ticking, and since this is not my truck I'm not sure if this sound is common or not? So I guess my second question is how much clearence is there from the stock rockers to the stock vavle cover and is my dimple safe?
To sum it up:
1. How do I know when I have drained the a/c's R-12 completely, and also how would you recommend doing it (I simply used something long and with my sleeve over my hand held the filler valve open, some crap squrited out so I left it a while then now I can get the ocassional hiss to come out, but I don't wanna pull that hose off until I am sure)
2. how much clearence is there from the stock rockers to the stock vavle cover and is my dimple safe?
Thanks alot guys
[ May 16, 2003: Message edited by: stonedchihuahua ]</p>
Old 05-16-2003, 03:08 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Post
Dave, what method did you use to vent the ac gas? if you did it the old fashioned way like your not sposed too, just wait for the hiss to stop.
Old 05-16-2003, 03:26 PM
banned
Post
by the way what is the proper way, Isn't it when you use the hoses with the regulators?
I do things the way that makes sense, specialty tool free
Old 05-16-2003, 03:28 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
To properly recharge the system, you need to draw a strong vacuum to insure there is no air or moisture that would pollute the new charge. That will also insure all R-12 is gone.
Old 05-16-2003, 03:32 PM
banned
Post
Well, basically I'm just trying to drain the system so I can change the pump, then they can get it recharged later... cuz the pump was seized and breaking belts and since i needs to be replaced anyways and I'm my g/fs family's BEOTCH I might as well fix it while I'm here.
Old 05-16-2003, 03:43 PM
Post
illegal in many countries around the world, just out on a heavy pair of heavy gloves and depress the schreader valve until no more hiss occurs. do this in a well ventilated area. and to recharge, take it to a shop, have them evacuate it for an hour or so and then charge it up.
what I'd do if i was in a non freon expelling country.
Old 05-16-2003, 03:45 PM
Post
you might be able to get by with just changing the a/c clutch assembly. way cheaper than a new compressor........
Old 05-16-2003, 03:59 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Post
When it stops hissing, it`s empty.
About then the Environmental Control boys pull in to the drive with handcuffs and a warrant.
VERY VERY stiff fine in the States.
Old 05-16-2003, 04:09 PM
troy-curt's Avatar
Post
Oh yea the dimple. If your dent is 1/4 or deeper right on the rocker, it could touch.
Use 2 or 3 ft. of rubber tubeing as a stethoscope one end tight on the dent other end at good ear.
Old 05-16-2003, 04:11 PM
troy-curt's Avatar
Post
Will Canada let you post from jail lol lolLOL
Old 05-16-2003, 04:27 PM
Post
[quote]Originally posted by troy-curt:
<strong>Will Canada let you post from jail lol lolLOL</strong><hr></blockquote>
LMAO
Old 05-16-2003, 05:00 PM
[email protected]
Post
Personally, if it was me and I didn't have the equipment to discharge the system myself, legally, I would have taken it to a shop to have it done. They could have saved the R-12 to recycle it, and put it back later. If you are going back with R-12, what you let out in the air may cost you as much as the new compressor.
Old 05-16-2003, 10:14 PM
banned
Post
meh, not my truck and also yes there are heavy fines here about a few grand.... then again a certain someone filled up the a/c in my car and is certified and said, ah to hell with it they gotta catch me in the act to fine me.
Oh yeah, since I was pretty sure the rocker wasn't gunna hit since my dimple wasn't all that big, I just pulled the main coil plug and turned the engine over, heard a ticking so I got my girlfriend to do it. Saw the spart from the main coil on time with the tick figured its' good to go... Hopped in the truck bagged it for a while around town after everything seemed to be working okay... Came back
I LOVE DOIN THINGS THE REDNECK WAY!
Old 05-17-2003, 07:16 AM
Post
[quote]Originally posted by stonedchihuahua:
<strong>
I LOVE DOIN THINGS THE REDNECK WAY!</strong><hr></blockquote>
I'm not quite sure if I know how to take that.....
<img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Old 05-17-2003, 07:24 AM
Barz51's Avatar
a.k.a. Rusty Shackelford
Last journal entry: Another one
Post
Hey, Dave if you leave the system open for more than a few hours you will need to change the dryer. It will absorbed the moisture in the air and become worthless to the system.
