Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - removing paint with a variable 7 inch polisher/ sander
  #43 (permalink)
Old 01-10-2018, 06:27 PM
Grizzdog 55 Grizzdog 55 is offline
Originally Posted by deadbodyman View Post
It looking good. the fumes can be bad if your right over it wear a mask circulate the air with a small box fan set low you don't want a wind to dry the stripper out just some air movement.
For removing old under coating I like to warm it up with a small propane torch and a diffuser tip then it scrapes right off in sheets sometimes it comes off cold without heat. I even welded a putty knife to an old air chisel, used at very low setting it'll pop off the real stubborned stuff
Thanks i will give it a whirl, Dave
