Replaced booster, now brakes work too good - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2018, 06:39 PM
70-K5's Avatar
Recently bought a 65 Chevelle, well built car, not like my last purchase but had a hissing from the brake booster.
Brakes still worked ok but had a massive air leak.
Picked up a replacement booster this morning, all the visual specs checked out so I brought it home, cleaned it and painted it.
After getting it installed and going for a test drive, I almost put myself through the windshield!
It is a disc/drum car with a single MC. ZZ4 crate with a 700r4.
Did I get the wrong MC? Of I am super careful I can modulate the brakes to a smooth stop but just a slight over application and it is the opposite of safe....
The Following User Says Thank You to 70-K5 For This Useful Post:
Texaswino (07-28-2019)
Old 07-08-2018, 07:02 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Couple of quick thoughts, MC should have 2 reservoirs, if it is nose diving could have the wrong combination valve also..
Gave up on the coupe ?
Pep
Old 07-08-2018, 08:37 AM
39 master's Avatar
booster
You can tone it down a bit by adjusting the pin between the booster and M/C. Doesn't take much, just screw it in one turn.
Old 07-08-2018, 10:07 AM
Old(s) Fart
Last wiki edit: Wheelbase database
That has no effect on the amount of assist from the booster. All it does is add slop in the system - free travel from the pedal before the brakes kick in.
Old 07-08-2018, 10:18 AM
70-K5's Avatar
Pep
Nope, it should be out driving later today...
I need to look more at this current setup. the si ge reservoir has a single line output to a T, that's it. Originally drum/drum setup, that was factory.
A dual MC with a proportioning valve might be the ticket but another can of worms.
or maybe it is a bad booster with no progressive power. the pedal moves about 1/2 way with no response, then there is only a small amount of travel that does all the stopping.
Old 07-08-2018, 11:43 AM
RWENUTS's Avatar
Did you check or change the pedal ratio?
You need 6 to 1 for non boosted. 4.5 to 1 for boosted.
Usually a new linkage hole in the pedal about 1 1/4 inches lower helps.
Old 07-08-2018, 11:46 AM
70-K5's Avatar
I put the rod back in the lower hole. I checked last night quickly that there wasnt a lower hole. Without a flashlight in a dark garage I couldn't tell if there was a hole higher up the pedal.
Just replaced the brake booster and master cylinder.. CadillacGirl_1966 Suspension - Brakes - Steering 6 05-29-2017 07:08 AM
Brakes...booster or no booster Tacuff1414 Suspension - Brakes - Steering 23 04-10-2014 08:33 AM
Replaced brake booster now pedal comes up slow eric32 Suspension - Brakes - Steering 4 09-07-2010 04:12 PM
Shop replaced timing chain - now oil leak - thoughts? dbuff Engine 3 01-15-2007 12:18 PM
Replaced Brushes & replaced battery terminals 78novaman Electrical 1 10-01-2006 08:39 PM
