respray tiny sandthrough or not - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Closed Thread
Old 07-01-2014, 08:35 AM
I have been getting my trans am ready for paint.
I kept spraying coats of spi epoxy and using a bit of glaze and blocking with 180, sprayed two more coats and blocked with 220, thought the car was pretty straight, so I sprayed two more coats, then sprayed my door inners with base clear. The first base clear i have ever sprayed, very exciting.
proceeded to do my final block sand on body of car with 320 and had a ton of sandthroughs, so i masked the door inners and resprayed two more good coats of epoxy. Got the whole car sanded with 320 with only 4 or five small sandthroughs, (mostly in places where chrome trim will cover).
I was hoping to sand again with 600 wet the skip the sealer step and just spray base clear on car.
With these small sand throughs, maybe a sealer will cover them good enough?
should I spray the whole panel again before sanding with 600?
can i just spray a bit over the tiny spot and resand with 320?
Quick reply to this message
Old 07-01-2014, 10:08 AM
I'd do a small test in a place you can't easily see. Recreate the problem and try a few cures.
I'd pinch the hose and carefully fade the color back onto the area, and clear again. You might get a slight halo... maybe not. Depends on the paint. Works in lacquer anyway.
Old 07-01-2014, 01:11 PM
Oh it's actually just still epoxy primer I'm still spraying, not base color, I just don't know if I can get away with a sealer coat on top before base or if I should try covering these spots with more primer and trying to feather it in or if I need to spray the whole car again and resand the whole car with 320
Old 07-01-2014, 01:33 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
no need to respray, just touch up the areas you sanded through and sand again. no big deal.
Old 07-01-2014, 07:57 PM
I have always sealed just about every car I have ever painted, but the last 4 I have done I am getting away from sealing. It is an extra step that takes longer, another coat to have dirt get in, and so on. When I am ready to start baseing and there are sand throughs, whether it is to bare metal or mabey filler, I will mix up a very small amount of epoxy and just blow those spots in. Wait a half hour then base as usual.
Old 07-02-2014, 06:25 AM
Last journal entry: Still running strong
Air brush, I have a cheap Badger air brush, pawn shop find. I used it a lot more than I though I would. They spray a thin coat so you have to put a few coats down.
Closed Thread
General respray and Ghost stripes mattip Body - Exterior 1 07-18-2011 11:40 AM
Tiny tiny solvent pop? brimcp99 Body - Exterior 25 05-03-2011 07:03 AM
Clear coat sandthrough oldred Body - Exterior 7 10-19-2006 07:07 AM
First Time Respray 67eleanor Body - Exterior 3 10-11-2006 09:45 PM
DBC or DCC for a Black respray? liteflihi Body - Exterior 2 07-08-2002 07:13 PM
