Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Reverse brake bleeding
Old 04-28-2019, 03:57 PM
brading brading is offline
Just use a oil can as picture, clean out first with brake fluid. Connect to each bleed nipple in turn with a rubber pipe starting with the furthest from the M/C. Used this method when having trouble getting the air out of the system
https://www.hotrodders.com/forum/att...1&d=1556488404
