Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Reverse brake bleeding
Old 04-29-2019, 01:11 AM
brading brading is offline
[QUOTE=LATECH;4669079]I would not use a used oil can as pictured but would use a new one that was rinsed absolutley clean with brake cleaner.
Brake fluid will not dissolve/reduce/remove/clean out oil .It will Contaminate brake fluid however.
Fair point. I meant a new not a used one which I should have made clear.
