Reversed Steering Arms - 1955 Chevy - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-31-2018, 03:45 PM
Old(s) Fart
Last wiki edit: Wheelbase database
Originally Posted by chasracer View Post
I have been working on autos now for a bit over 54 years. I have built race cars from the ground up and I have worked in the race car industry. I have worked in body shops, car shops and independently - I might just know a thing or two about steering systems. I don't expect anyone to know that information but just asking a basic question seems to be a tough act around here.
Thanks for reply.
Unfortunately, the questions to forums from clueless people far outnumber those from people who actually understand what's going on. Until the mind reading thing is working, the rest of us don't know the skill set or tools or facilities of the person asking the question. Good luck with your project.
The Following User Says Thank You to joe_padavano For This Useful Post:
adantessr (11-14-2018)
  #17 (permalink)
Old 10-31-2018, 04:53 PM
RWENUTS's Avatar
[QUOTE=chasracer;4631453]Well - that's the question. I still don't know if those arms are commercial or if they were custom made for the owner. And I certainly understand people trying to help with their input, but telling me I am going to fail up front is like telling the first guy that made a wheel that it won't work - unless you have performed the same exercise, you really don't know if it will or not.
I have been working on autos now for a bit over 54 years. I have built race cars from the ground up and I have worked in the race car industry. I have worked in body shops, car shops and independently - I might just know a thing or two about steering systems. I don't expect anyone to know that information but just asking a basic question seems to be a tough act around here. quote
I’d say they’re custom made from the pic.
Maybe you could flip the steering knuckles side to side to get the arms in front.
  #18 (permalink)
Old 10-31-2018, 04:57 PM
Old(s) Fart
That's the one thing you CANNOT do.
The steering arms are angled to provide the proper ackerman angles when turning. Rear steer geometry typically has the outboard tie rod end ball centerline further outboard than the kingpin axis (the line through the control arm ball joints), so the steering arms are angled outward. Front steer requires the tie rod ball joints to be INBOARD of the kingpin axis, so the steering arms are angled inward.
RWENUTS (10-31-2018)
  #19 (permalink)
Old 10-31-2018, 05:08 PM
ericnova72's Avatar
More for Less Racer
Are you sure it was a stock spindle??
Picture is joe's link doesn't look like a stock spindle at all, unless I just can't see enough of it.
One thing is true that has been said....a longer steering are is going to increase turning radius, not decrease it.
  #20 (permalink)
Old 10-31-2018, 05:11 PM
ericnova72's Avatar
More for Less Racer
The steering arms unbolt from the spindle, and the arms can be reversed.
Still doesn't fix the possible bump steer issue.
  #21 (permalink)
Old 10-31-2018, 05:17 PM
Old(s) Fart
Never mind bump steer. Again, it's the ackerman steering angles that are the most important. If you simply swap the arms around, the front tires will toe in on turns and scrub.
  #22 (permalink)
Old 10-31-2018, 05:30 PM
ericnova72's Avatar
More for Less Racer
Maybe 1964-72 Chevelle arms, which are front steer, if the bolt spacing is the same??
I know '64-72 Chevelle and '68-74 Nova/'67-69 Camaro the spindle is the same, the only difference is the rear steer or front steer arms, which unbolt from the spindle.
  #23 (permalink)
Old 10-31-2018, 05:31 PM
RWENUTS's Avatar
Following up on the pic I found this.
He might tell you where the arms came from.
Project Details – Rutherford Motorsports
  #24 (permalink)
Old 10-31-2018, 05:41 PM
Old(s) Fart
And this is why people were so negative to the OP's original question.
You can't just bolt random steering arms onto spindles. You have to figure out the correct length, angle, and position for the car to steer properly. That means you have to plot the steering and suspension motion in three dimensions to properly select the steering arm geometry.
  #25 (permalink)
Old 10-31-2018, 06:02 PM
ericnova72's Avatar
More for Less Racer
Only reason I mentioned that specific arm is that it derives from the Tri-5 suspension, the A body is basically the next generation of it.
Of course everything needs to be checked and measured.
  #26 (permalink)
Old 10-31-2018, 07:02 PM
chasracer's Avatar
True Hotrodder
Project Details Rutherford Motorsports
Ha-ha - nice detective work but that's my website.
  #27 (permalink)
Old 10-31-2018, 07:08 PM
chasracer's Avatar
True Hotrodder
Thank you for the information - I appreciate it. I'm thinking that the steering arms in the photo are custom units that the owner had built. I already talked with one fellow that attempted the stock arms reversed. Said it worked just fine except for the lack of turning radius. The R&P simply didn't have enough "throw" left to turn the wheels completely. Moving the rack back is one solution but you run out of room if you are trying to stay with the stock a-arm locations.
I'll do some checking on the A-Body stuff.
  #28 (permalink)
Old 10-31-2018, 07:31 PM
RWENUTS's Avatar
Oops!
Thought I was gonna get a hero cookie!
Onward and downward.
Have you considered a front clip swap. To a front steer like a 75 nova. Similar front stuff like your 55.
Just a thought!
  #29 (permalink)
Old 10-31-2018, 09:14 PM
You have this exactly backwards. Rear steer arms angle in and front steer arms angle out
  #30 (permalink)
Old 10-31-2018, 09:17 PM
There is another difference, the rear steer arms are angled much lower than the front steer arms.
Eliminating play on reversed corvair steering box jdr5152 Suspension - Brakes - Steering 7 04-05-2016 02:23 PM
Besides the reversed corvair steering box 31chevy Suspension - Brakes - Steering 4 12-30-2007 07:04 PM
Yikes! Reversed the Pos/Neg leads on battery JohnTN Electrical 12 04-01-2005 10:37 AM
reversed polarity..what have I toasted? TVR383 Electrical 8 11-26-2004 07:02 PM
Reversed Polarization???? badA31 Electrical 10 11-25-2004 10:46 PM
