Richmond 2-speed won't stay in gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2020, 04:05 PM
any trans folks have a good guess on why this trans jumps out of gear during a race? I loaned it to a guy and he has run it 5-6 races but has to use a bungee cord to keep it in gear.
It uses a special synchro ring which broke years ago which I had to replace and I can't see it being worn out as it has only 30-40 races on the trans total.
Old 07-26-2020, 04:13 PM
Depends on how hard he is on them when shifting.
It only takes once to trash one.
Sent from my SM-G965U using Tapatalk
Old 07-26-2020, 04:28 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I'd pull the side cover and look for a bent shift fork. Look for the slider to not be fully engaged.
Does it do it on or off throttle?
Old 07-26-2020, 04:52 PM
jumps out under power, but would probably jump out when lifting too.
Old 07-26-2020, 05:51 PM
Could it be moving around on the bell housing? Is the bell straight and flat? Are the bell housing locators long enough if this has a mid plate?
Has the drive shaft ever bottomed out on the splines or knocked out the rear seal?
Does the car have a tail shaft support? if not, I wonder if chassis flex is pulling the shifters enough to pull it out gear?
Old 07-26-2020, 06:04 PM
flex is something I didn't consider. It is a 25 year old metric chassis truck, has been updated somewhat. Has no rear mount.
Old 07-26-2020, 06:19 PM
If you get a practice night perhaps disconnect the shifter and leave it high gear. Push it off and run some laps.
The Following User Says Thank You to johnsongrass1 For This Useful Post:
AutoGear (07-28-2020)
Old 07-28-2020, 07:41 AM
check bellhousing alignment and parallelism between the back face of the bell and the flywheel. Theres a company in syracuse that has steel shift forks made in USA. T10 sidecovers can be finicky. Their detent system is a lot more complex than the Muncie stuff. Hows the fit between the slider and the hub? You can use an Italian Muncie Torque-Lock and use the Muncie 297k strut and spring kit. I also know where there are billet struts/keys/dogs for the Muncie
The Following User Says Thank You to AutoGear For This Useful Post:
lmsport (07-28-2020)
Old 07-28-2020, 12:55 PM
If your guy has a Hurst shifter; I know Crash Enterprises in Wisconsin has great deals on restored Hurst pieces, overhaul kits and also customized installations.
Old 07-28-2020, 01:12 PM
Imsport.
Is this a 2 speed made with the road-racing lug style synchro ring, or the dedicated Richmond 2 speed dog-ring setup that used the stock fork arrangement?
The lug indexed synchro ring setup uses stock gears...When Regal Beloit sold Richmond to Midwest Truck, the gears were tooled up 'off-shore'. You may have an issue with the included angle of the synchro ring and the gear being different...and having trouble. You'd have to look at everything with an optical comparator. I have one and would be happy to do it.
Old 07-28-2020, 01:42 PM
Looks similar to this tremec setup
http://www.5speeds.com/racing/dogring.jpg
Old 07-29-2020, 07:05 AM
Is the lug plate removeable from the gear, or is it a 1-pc forging? Are they spur gears or helical?
Old 07-29-2020, 07:25 AM
The lug plate is replaceable, one broke the first time out when the trans was new.
I don't recall it having spur gears but am not sure.
Old 07-29-2020, 08:27 AM
You CAN get an oscillation from that snapring'd lug plate on the face of the gear. If the fit is too loose and hes WFO in high gear, an oscillation plus a worn sidecover, bum fork, bad tire/rim/brake balance, etc...could tip it over the edge. Youll usually see some fretting on the gear/lug plate if you look close with a lupe in the splines, and the snapring will have a shiny spot. Some guys will also 'dress' the lugs themselves as they get burred up in-use with a dremel or whatever. Once you lose that square edge; it becomes a ramp.
lmsport (07-29-2020)
Old 08-01-2020, 03:27 PM
This also can result from a bearing problem. You’re going to have to open it up to do a careful inspection not only for damaged or broken parts but also why they broke, sounds like this has had problems from the start.
Bogie
