Rocker spray - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2016, 01:48 PM
Rocker spray
AKA "stoneguard, rocker panel spray, texture, etc"
Looking for stone guard in qt can. All I can find locally is the odd spray can of some crap, or what they say is "paintable under coat" (it ain't paintable)
Used to be able to get it by the pint, quart, and gallon. But no-one seems to carry it anymore that way.
Any ideas?
Old 10-01-2016, 04:20 PM
OldTech's Avatar
Could you use "bed liner"?
Old 10-01-2016, 07:18 PM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
We use it all the time and most paint stores can readily get it if you know your part number.
What you might be running into with the not finding is that the popular solution now is called "no cleanup rocker guard" and comes in a blue can the size of a big aerosol. You attach the can to a disposable nozzle which attaches to the gun. So you just leave the old nozzle in until the next use and detach the gun. Its pretty much same as the old stuff just in a different container-
3M No Cleanup Rocker Gard Coating 08949
Here is some rubberized black in a quart size for a traditional "yes-cleanup" gun-
3M Body Schutz Rubberized Coating Black 08864
I'd bet that other brands have modern equivalents but these are what I'm familiar with. In my opinion, the beige no-cleanup stuff lays out better than the rubberized black which is more grainy looking and roughly textured. As you know, appearance is ultimately dependant upon how its sprayed.
Old 10-02-2016, 12:42 AM
Rocker spray
Here you go, www.semproducts.com/refinish-chip-guards
You may have to special order from some places, most jobbers only carry what they can turn around quickly
The Following User Says Thank You to F1 Owner For This Useful Post:
st3gamefarm (10-02-2016)
Old 10-02-2016, 06:13 AM
delawarebill's Avatar
rattle can spray bed liner
i used this from auto parts store when i changed out the front susp on the fairlane.. went on very nice. i power washed first.
i sold the car shortly after so i don't know how well it holds up.
Old 10-02-2016, 06:22 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
Those part store rattle cans MUST say "rubberized" paintable undercoating Or they don't dry enough to paint.
The paint store will have a good selection 3m and other brands that would be better, Even HF has some now
Old 10-02-2016, 03:19 PM
I've found that even though the can says "rubberized" and "Paintable", very few undercoatings actually are. But I've found that Rubberseal has a good product that is actually paintable. But not available on short notice. My usual paint suppliers have stopped selling chip guard in quarts, and only offer it in aerosol cans.
So, today I decided to make my own "textured" finish. I had some industrial urethane left over from a previous job. I catalyzed it, and dumped it into the gun, with a 1.4 tip, and about 1-2 psi air pressure, and no reducer, I got the texture that I was after. Surprizingly it worked quite well.
Why I didn't think of this before is beyond me. Thanks for the replies, and good links.
Proper rocker stud trouqe for sbc rocker studs? Chevy_14 Hotrodding Basics 2 07-31-2014 06:23 PM
Floor/ Rocker/ Inner Rocker Connection 123pugsy Body - Exterior 7 02-07-2014 08:09 AM
should I swap spray guns mid- spray Northstar T Paint 7 10-09-2013 07:53 AM
Spray and re-spray...(long one) VWFan Body - Exterior 9 03-17-2011 10:17 PM
rocker stud to rocker clearance 85406 Engine 2 07-16-2004 09:25 PM
