A Rostra cruise control grounding issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2019, 01:46 PM
I have put in a Rostra cruise control in my 78 El Camino. I sanded the fender to bare metal where I put the ground bolt. When I use my volt meter, going from cruise control ground to the battery ground, checking ohms,I don't get a reading. I'm guessing the ground isn't working, since there's no reading. Am I correct? If so, how do I make it a better ground? Thanks for your help.
Old 11-28-2019, 04:23 AM
75gmck25's Avatar
Last journal entry: Engine replacement
If you are checking continuity between the cruise control ground screw and your fender ground and not getting a reading, you have a broken wire.
I would expect that grounding to the fender would work, but there may be some spacers/insulators between the fender and the rest of the body. You might try installing a small ground bus on the firewall instead, and see if that works better.
Bruce
Old 11-28-2019, 05:26 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Could run a braided ground strap from the block or frame, to the fire wall, use the whole body as a buss.
Just a question, reading the sanded area of the fender and the bat ground, you seeing continuity ? If yes the problem is with the CC unit, that ground wire might be broken.
Pep
Old 11-28-2019, 07:29 AM
Thanks guys and Hope you have a happy Thanksgiving. Yes, I'm trying to read the continuity between the ground of the cruise control panel and the ground for the battery. I was told by the tech people at Rostra to get a reading for those points. I put the fenders on myself and there's no bushings or rubber between them and the body. I'm terrible at wiring. I really appreciate your help.
Old 11-28-2019, 09:51 AM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
Is your cruise control not working? What are your symptoms? I had hell with mine but finally got it working fine..
Old 11-28-2019, 10:56 AM
Not sure if this is similar to what you have... Never installed this before. What appears to be the ground wire coming from the box is very small, so not running much amps. The ring connector in the loom is typical low amps. If this is going under the dash, just run to a ground there. If under the chassis, and/or any question..., just splice in a 14G ground and run to batt terminal. A 20ft roll of 14G Black is only about $8.00. Plus looking at the unit, I would suspect, non protected circuit card. Having a separate direct power and ground allows you to disconnect and isolate in the event you need to weld and protect it from power spikes.
Name:	Rostra Image.jpg
Old 11-28-2019, 12:25 PM
ogre's Avatar
the 'Duracell Project'
a quick check would be to run a temp ground wire to the battery
i've had the rostra global cruise on my 58 truk for 10 years without a problem
the only thing i'd suggest is to set the dip switches to minimum aggressiveness for everything to avoid surge
The Following User Says Thank You to ogre For This Useful Post:
Foperfoauto (11-28-2019)
Old 11-28-2019, 01:10 PM
blwn31's Avatar
Is there paint at all the mating surfaces where the fenders bolt to the core support and the body? If so, you may not have any continuity since the parts are insulated from each other. You may need to put bonding straps at other locations on the fender to get the fender grounded to the battery.
Keith
Old 11-29-2019, 10:56 AM
This cruise control is used but a new installation for me. I haven't tried it on the road yet. I'm trying to get the LED functions to work according to the directions in the manual. There is a green light that is to show up in the LED control panel that's mounted on the driver's fender. I put the new fenders on about 4 years ago. They have paint on them where they are attached. The ground at the battery seems to work on. That doesn't mean the other side will. I'll try running an extension on the ground for the cruise control. Thank you all for your help.
The Following User Says Thank You to redsag 78 For This Useful Post:
Foperfoauto (11-29-2019)
