Rough riding 39 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2019, 03:22 PM
Would like to soften up the ride of my 39 Chevy business coupe. It has a Mustang II type front end, Chevy Nova rear end. Springs and shocks were purchased from a well known engineering company. Not sure if I can mention by name the companies that I've bought my suspension parts from. The ride is rough there seems to be no "floating", at times I almost feel like the rear tires are coming off of the road and bouncing. Will be glad to answer any questions.
Old 07-16-2019, 06:55 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Most likely it is your shock valving. If the shocks are too stiff you can get what you describe. Either a softer shock or adjustable shocks are in order. Also what are your spring rates..
Sam
Old 07-16-2019, 07:27 PM
36 sedan's Avatar
Check your bump stops on your rear end housing. Sometimes when the car is lowered the stock bump stops need to be modified. If the the bump stops engage to soon on a bump it can severely limit the axle housing's travel, which in extreme cases can cause the rear tires to loose contact with the pavement.
Old 07-16-2019, 08:06 PM
36 sedan
Thanks for your suggestion. How do I determine if the bump stops are engaging to soon.
Charlie
Old 07-16-2019, 08:42 PM
36 sedan's Avatar
Bounce the rear of the car to check the suspension's normal travel, have a friend measure the down travel and use this measurement to see how much clearance there is between the axle housing and the stops on the frame. The stops are designed to limit the excessive travel and prevent damage, under normal driving and road conditions the stops usually do not have any contact.
Old 07-16-2019, 09:41 PM
36 sedan
Will grab a friend in the next day or two and check travel. Must admit this bump stop is all new to me.
Charlie
Old 07-17-2019, 06:30 AM
39 Sedan's Avatar
You might check your shock length as well. I have a sedan version and mine rode rough and bounced at times as well. I have either a nova or camaro rear end in it as well. I ordered new 3 way adjustable shocks for it. When they arrived i thought they were way to long until i actually jacked up car and did the measurements properly. Come to find out the shocks it had on it were almost 4" to short!! I installed the new shocks and sat them on the middle setting. Have not taken it on any long road trips but to a couple shows near by and so far i have to say ride is pretty nice and improved a 100 percent.
Old 07-17-2019, 06:35 AM
RWENUTS's Avatar
Originally Posted by 39BC View Post
36 sedan
Charlie
Make sure itís a skinny friend! LOL!!
Not much room under there.
Iíve done the bounce test but I put a dab of grease on the bump stop. If thereís contact youíll see easily if thereís contact.
The Following User Says Thank You to RWENUTS For This Useful Post:
36 sedan (07-17-2019)
Old 07-25-2019, 04:40 PM
Yes I am still here I haven't forgot you guys and all the help that you have been. Haven't really done anything on the car since my last post. Car is going up on lift tomorrow. We will be looking at all of your suggestions. Contacted the company that I bought springs and shocks from. Was able to ascertain information on the shocks but couldn't get any kind of a spring rate on the leaf springs. Did make a 150 mile round-trip to a hamburger joint (Moonshine Store) on some of the finest roads that Illinois has, I am being facetious some of the roads were terrible. On the way back we stopped at a milkshake joint I told them to just throw all of the ingredients in the passenger seat I will make my own milkshake. Will keep you posted on what I find out thanks again for your helpful suggestions.
Charlie
The Following User Says Thank You to 39BC For This Useful Post:
PHWOARchild (07-26-2019)
Old 07-26-2019, 06:46 AM
39 Sedan's Avatar
Nice road in this state where? Where exactly is Southeastern IL just trying to figure out how close we are to each other.
Old 07-26-2019, 10:18 AM
39 Sedan
Grayville, I 64 Illinois Indiana border. Sent you a private message yesterday.
Charlie
Old 08-11-2019, 07:50 AM
Hi
Did put the car up on the lift on July 26 as planed. Removed the next to the shortest leaf on both rear springs. Drove car around town seemed to help. Didn't take the car out on the open road untill yesterday, drove about 100 miles. What a difference the car road so much better no hard thumps like before. Thanks everyone who contributed to this thread. Look for my next thread about my steering. Untill then good motoring.
Charlie
Old 08-12-2019, 07:35 AM
39 Sedan's Avatar
Good deal See ya in a few weeks Maybe
