Rust Remover - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2017, 12:22 PM
Rust Remover
Needless to say, I am a skeptic when it comes to ads about products, but for the money, I had to try this stuff. All I can say it is incredible. My project has surface rust and I was going to get it sandblasted. I thought before I did that, I would try this product for $12.99 a quart. WOW! It really works and is easy,quick to use. I did 2 control arms this morning in about 1/2 hour. Look at the before / after results.
Name:	TOP of LOWER A ARM.jpg
ID:	370697   Click image for larger version
Name:	UPPER A ARM without RECESS SIDE.jpg
ID:	370705   Click image for larger version
Name:	DERUSTED  A-ARMS.jpg
Old 08-15-2017, 12:25 PM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
And the name of this incredible stuff is????...
Old 08-15-2017, 12:27 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Inquiring minds would like to know..............
454 RATTLER
The Following User Says Thank You to 454 Rattler For This Useful Post:
astroracer (08-15-2017)
Old 08-15-2017, 12:35 PM
If I tell you, I have to kill you then. All kidding aside, it is called 3X Rust Dissolver and, I did make a mistake, it is $13.99 per quart. I bought it from Speedway, part number 307-99024, and I can't say enough good about it. The stuff really works. I have a whole lot of surface rust on my whole project just from sitting. Has never been outdoors, but sitting unprimed and unpainted. I didn't even have to wire brush or anything. I bought a whole pack, 20, of cheap 2" foam brushes from Wally World (Wal-Mart) for $3.97 Bruch this stuff on and you can immediately see it dissolving the rust. I let it sit about 1/2 hour, keeping it wet as directed on the bottle. When all is dissolved, I use paper towels to wipe off. Then wipe off again with mineral spirits. Walla. ready to prime. By the way, I did my whole rear axle housing, 4 bars, 2 brake drums and 2 front control arms on just a little less than a quart. That also included practicing first on some old scrap pieces of metal.
Old 08-15-2017, 12:44 PM
Derusted axle housing
Here are some pics of my rear axle housing when I first tested the stuff. You can see the difference on the 4 bar and housing
Name:	After 20 minutes.jpg
ID:	370721   Click image for larger version
ID:	370729   Click image for larger version
ID:	370737   Click image for larger version
Old 08-16-2017, 07:42 AM
PHWOARchild's Avatar
I buy 5 pound bags of citric acid (used in food processing grade) and it works well. The mix I like is 1 pound to 5-gallons of water. And it is CHEAP.
I've dipped control arms, bumper brackets, loads of small parts (in a pool skimmer basket) and after a few days the rust washes off easily with a plastic brush.
I use old cat litter plastic containers and have a bigger 20-gallon Rubbermaid tub. I did the front of my hood recently in a bigger container (under the bed storage unit).
But whatever you find and share helps us all.
Old 08-16-2017, 08:04 AM
Thanks for sharing. I guess there are other things out there, but I saw this and said, what the Hell, I will not be out that much if it doesn't work. Hopefully, I will have my chassis finished by next week and can go on to assembly, of the complete chassis. Then, in the fall and winter, work on getting the body set up properly. Hope the results I see now, with my running gear, shows with the rest of the car.
Old 08-16-2017, 06:01 PM
OK. Got all of the suspension components, derusted primered and painted.Going up to Bassett Wheel, tomorrow, to pick up my mock up for the front wheels. Problem is now, being the suspension is all apart, I cannot mount the wheel for fitment. Hopefully, I will start, Friday, derusting the chassis and primer/paint in within a few days. that way, next week, if all goes well, I'll be able to start reassembling the drive line and then I can start the plumbing work, you know, fuel line, brake lines, etc. I can really see progress now. Here are 2 of my finished control arms. The other two are still drying
Name:	PAINTED CONTROL ARMS.jpg
Old 08-17-2017, 01:16 PM
astroracer's Avatar
They look nice! It sure is an energy booster when you can see things getting done... Good job!
Old 08-17-2017, 05:00 PM
Thanks for the encouragement. Just got back from Bassett Wheel Company, with the mock-up wheel for my front wheels. What a great company to deal with. The plan is to start tomorrow, derusting my frame. Hopefully, I will have it derusted, primed and painted, next week sometime.
Old 08-18-2017, 08:41 AM
NEVER SATISFIED !!
How will you apply it to your frame. I assume that you brush it on. Then what ?
454 RATTLER
Old 08-18-2017, 09:41 AM
OK. I use cheap, cheap Wally World 2" foam brushes, 20 for $3.97. Apply the dissolver, let it do it's magic, wipe off with rags or paper towel and let dry a few minutes. Then I wipe off again with mineral spirits or acetone. Let dry, prime and paint. Easy and quick.
454 RATTLER
Old 08-18-2017, 03:12 PM
454 RATTLER
Did you see my reply?
The Following User Says Thank You to V8Square For This Useful Post:
454 Rattler (08-19-2017)
Old 08-18-2017, 04:42 PM
Rear end stages...
Name:	PAINTED. INSTALLING NEW STUDS.jpg
ID:	371929   Click image for larger version
Name:	PAINTED WITH 3RD MEMBER INSTALLED.jpg
ID:	371937   Click image for larger version
Name:	PAINTED AND ASSEMBLED.jpg
ID:	371945   Click image for larger version
ID:	371953   Click image for larger version
ID:	371969   Click image for larger version
Old 08-19-2017, 09:15 AM
NEVER SATISFIED !!
I just saw your reply. It looks like that stuff really works great. Thanks for the info and please show us the frame when you're done.
454 RATTLER
rust remover 62440 Body - Exterior 11 09-14-2014 05:58 AM
D-rust it, Safest rust remover, Evapo rust. 35prog Body - Exterior 21 05-02-2009 03:56 PM
Safest Rust Remover 62ImpalaSS Body - Exterior 33 06-17-2008 07:04 PM
Rust Remover Kevin45 Body - Exterior 2 12-07-2003 06:09 PM
