S10 4x4 Extend Transfer Case shifter.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2011, 08:29 PM
Got a 1990 S10 floor shift transfer case. Did a 3 inch body lift. I would like to extend the shifter a few inches. Does anyone have knowledge of a way to extend it?
Old 02-02-2011, 09:37 PM
I'd go to a machine shop with a diagram of what I need and see what they can make me.
Old 02-02-2011, 10:36 PM
mud.man.rj's Avatar
t case shifter.
When you get all set up with it extended, make sure the shifter moves far enough ahead to stay in gear. Usually with a body lift the shifter will jump out of gear under load so notch the floor out a bit to make sure it goes all the way in. Had it happen on 4 trucks so far. Better to find out ahead of time.
Old 02-03-2011, 08:27 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Let's move this to General Rodding Tech.
Dan
Old 02-03-2011, 09:05 AM
1971BB427's Avatar
Why not just pull the shifter off and cut the shft, then weld in an extension. Paint it and put it back on.
Old 02-03-2011, 08:35 PM
cont...
The shifter I have is the push button floor shifter. How do you remove the knob? Most shifters like this you would pull the button out and remove the snap ring that holds the knob on. However, on this shifter the button is not wanting to budge. My thought was to remove the knob then see if I can extend the shaft. I would still need to be able to depress the button though.
NP 203 Transfer Case Shag0215 Transmission - Rearend 1 03-08-2010 01:45 PM
Transfer case - NP 203 - 205 scook Transmission - Rearend 3 01-10-2010 12:28 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
transfer case help 53fordguy Transmission - Rearend 4 03-19-2005 11:54 PM
transfer case sweethome18 Hotrodders' Lounge 2 10-26-2002 09:23 PM
