S10? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #16 (permalink)
Old 03-07-2019, 07:34 PM
Dimwit
Last journal entry: Harvey did it.
I've started working on the tail piece of the driver side fender, using the pieces of sheet metal I'd bent up some months back. I couple were so covered with surface rust that I attacked them with some steel wool. I had not bent the lower fender edge and had to cut some reliefs to get it to bend properly. I used a cardboard cutout of the passenger fender to mirror the curve for the driver side; it matches pretty well. I assembled two pieces and spent the rest of the day trying to hammer out a pronounced dip where I'd welded. After making no progress with a hammer and dolly, a mallet and lead bag and a shrinking disk, I said "leave it for Bondo". I checked the fit and discovered the driver fender is an inch longer than the passenger side, so I'll be cutting out the dip (highlighted with blue tape) and reassembling the tail piece. On another day.
ID:	441109   Click image for larger version
ID:	441111   Click image for larger version
ID:	441113   Click image for larger version
ID:	441115   Click image for larger version
  #17 (permalink)
Old 03-17-2019, 07:48 PM
Dimwit
Finally got to work on the fender after a day and a half of yard work. Made the initial cut on either side of a strip of 1 inch tape. Found I needed to cut another inch to get the length (78.5 inches) to match the passenger side. Last weekend, I'd bought some butt weld clamps at Harbor Freight - 8 clamps for $6. Boy, I don't know how I've worked in the past without these clamps.
ID:	441439   Click image for larger version
ID:	441441   Click image for larger version
ID:	441443   Click image for larger version
  #18 (permalink)
Old 03-21-2019, 08:58 PM
Dimwit
Tacked the tail piece in place after a little more trimming. The dip where the two pieces are joined has almost been eliminated. Shifting the tail piece around to keep the flange in the proper location has canted the bottom up, leaving a widening gap where the flange should be on the trailing edge. I used the brake and shrinker to make a new piece for the trailing flange.
ID:	441527   Click image for larger version
ID:	441529   Click image for larger version
ID:	441531   Click image for larger version
  #19 (permalink)
Old 03-24-2019, 08:14 PM
Dimwit
2019-03-24 9:13pm
Finished welding in the re-positioned tailpiece and flange. Fitted the final bit between the tailpiece and the side of the hood, then trimmed most of it off. Now to make the last bit of fender flange.
ID:	441649   Click image for larger version
ID:	441651   Click image for larger version
ID:	441653   Click image for larger version
ID:	441655   Click image for larger version
  #20 (permalink)
Old 04-20-2019, 07:42 AM
gegcorp2012's Avatar
Nice work and thanks for sharing how you are using the wheel and shrinker/stretcher and other hand tools to work the metal. I got one of Ron's books to learn how he works metal, it's good to see a project with so much custom work.
Sent from my SM-J700T using Tapatalk
The Following User Says Thank You to gegcorp2012 For This Useful Post:
Supercharged03 (04-20-2019)
  #21 (permalink)
Old 05-04-2019, 08:18 PM
Dimwit
You can tell from the first photo that the driver's side fender meets the hood side an inch or so higher than does the passenger side. I missed getting a photo of the two fenders side-by-side, but I have one of the cardboard template I made from the passenger side up against the driver side. I cut out the three foot section from the top of the driver side fender, ran it back through the shrinker-stretcher and English wheel and welded it back in place. The height of the driver side is much closer to the passenger side now.
ID:	442963   Click image for larger version
ID:	442965   Click image for larger version
ID:	442967   Click image for larger version
  #22 (permalink)
Old 08-11-2019, 07:37 PM
Dimwit
I've had a long break. A fellow commented while viewing my build and discouraged me a bit. Oh well. I just need to pull up my big boy pants and get on with it.
I've finished reworking the flange on the driver's side front fender, reminding myself that perfect is the enemy of good. Here are a couple of photos with the headlight buckets held in place with magnets. I may play with the placement a bit more.
ID:	446129   Click image for larger version
The Following User Says Thank You to Supercharged03 For This Useful Post:
123pugsy (12-14-2019)
  #23 (permalink)
Old 08-12-2019, 10:51 AM
WABOOM's Avatar
I'm dying to know what the discouraging comments were.
That is gonna be a sweet custom btw.
The Following User Says Thank You to WABOOM For This Useful Post:
Supercharged03 (08-13-2019)
  #24 (permalink)
Old 08-13-2019, 08:59 PM
Dimwit
The fellow took a look at the passenger side and said, "I can't tell if it's comin' or goin'."
That's not the worst comment, though. On viewing my completed A-pillar, my son the welder said, "Well, it doesn't look as bad as I thought it would."
I thrive on high praise.
  #25 (permalink)
Old 08-25-2019, 07:32 PM
Dimwit
The 39-41 Chevrolet headlight bucket housings have a smaller diameter than do the headlight buckets I bought. I removed the internals of the bucket housing by grinding away the rivets. Then I cut away the flange on the housing that would accept the trim ring. This was a mistake - I should have left the rolled edge of the flange in place. Oh well. I ground out the rivets that held to housing together and spliced in a piece to increase the housing circumference to match the trim ring, Now to create an anvil against which to roll the edge of the housing.
ID:	447105   Click image for larger version
ID:	447107   Click image for larger version
ID:	447109   Click image for larger version
ID:	447111   Click image for larger version
  #26 (permalink)
Old 09-29-2019, 07:46 PM
Dimwit
My son the welder cut a semi-circle anvil from some 3/8 inch plate and it's worked very well to roll the edge with a body hammer. I spliced in about a two inch section of 18 guage to expand the diameter of the headlight buckets. They now match the trim rings I had purchased years ago from a now-defunct Harley-Davidson distributor.
Son also gifted me a poor man's metal bandsaw. He'd built a wall mount for a hand-held HF bandsaw some years back. He's since purchased a bigger unit and no longer had need for this one.
ID:	448413   Click image for larger version
ID:	448415   Click image for larger version
ID:	448417   Click image for larger version
ID:	448419   Click image for larger version
  #27 (permalink)
Old 11-05-2019, 06:56 PM
Dimwit
I used a sheet metal punch my son inherited from my dad to cut a bunch of brackets. I had planned to bend the brackets to 90 degrees and weld them to the inside of the headlight buckets. After looking more closely at how the headlight backing plates fit into the buckets, I decided to simply weld the brackets to the rolled edge of the buckets. I used a cereal box to make a template of the mounting holes in the headlight adjustment plate and welded the brackets to the bucket edge. Clip-on nuts attach to the brackets and the headlight adjustment plate bolts to the brackets. The buckets look pretty nice with the stainless trim ring in place.
ID:	449371   Click image for larger version
ID:	449373   Click image for larger version
ID:	449375   Click image for larger version
ID:	449377   Click image for larger version
  #28 (permalink)
Old 11-05-2019, 07:21 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
I know how I missed this thread... the title. But wow! Not anymore, I won't. This is wild, I gotta see the whole long strange trip.
Is there a drawing or anything, of what you're going for?
The Following User Says Thank You to idrivejunk For This Useful Post:
Supercharged03 (11-06-2019)
  #29 (permalink)
Old 11-06-2019, 07:34 PM
Dimwit
Thanks for following.
I don't have a drawing but I have a couple of magazine clippings on the garage wall that illustrate the fender lines I have in mind.
idrivejunk (11-07-2019)
  #30 (permalink)
Old 11-24-2019, 08:38 PM
Dimwit
I'm getting prepared to place the headlight buckets into the front fenders, so I made a couple of stands to hold a horizontal brace. The photo highlighted some flaws, one being the lower flange on the driver's side fender. I fabbed a replacement piece and welded it in.
ID:	449935   Click image for larger version
ID:	449937   Click image for larger version
ID:	449939   Click image for larger version
ID:	449941   Click image for larger version
idrivejunk (12-15-2019)
will s10 pickup fit S10 blazer chassis? peab007 Hotrodding Basics 4 02-28-2012 08:45 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 09:28 PM
chev S10 convertible top ? Ron Wiebe Body - Exterior 8 08-23-2003 09:36 AM
s10 frame question mitmaks Body - Exterior 7 02-04-2003 03:53 PM
Drag race Wing For S10 Pickup B-D Drag Racing Body - Exterior 3 08-25-2002 08:15 AM
