Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - s10 motor mounts
Old 06-22-2018, 05:26 PM
eric32 eric32 is offline
You can use the 4.3 engine mounts for a v8 swap but from my research the 2.8 engine mounts are a lot more easier to work with and give more forward and back movement compared to the 4.3 engine mounts.
I have a 96 chevy s10 which is very close to a 98 s10 and my v8 swap is using the 2.8 mounts on the frame and is from trans dapt name brand and can be had for pretty cheap and not cost an arm and a leg. I also moved my radiator forward by cutting into the core support and customizing a shroud that is for a 4.3 to fit and work for a mechanical fan.
https://www.summitracing.com/parts/trd-9906
