s10 motor mounts - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-25-2018, 05:17 PM
Itís a first gen, but hereís the clearance with the engine mounted all the way back. My radiator is just a hair too big to recess, so Iím waiting for a non rainy day to pull it out and clearance the upper support. This is how I got it btw and it runs about 215. I want to find a Taurus fan and shroud.
Sent from my iPhone using Tapatalk
  #17 (permalink)
Old 06-25-2018, 06:17 PM
I'm going to use a corvette 4 core one I don't want any problems with it
  #18 (permalink)
Old 06-26-2018, 11:08 AM
2001Blazer4x4's Avatar
Redneck Professional
Originally Posted by 1953bigblock View Post
Thanks mine is only a 2 wheel drive I know exhaust would be hard to do with the fuel tank in the way that is why I thought of going with side pipes most of the headers they say they don't fit manual transmission I will have to call to make sure
My S10 is a 2WD. My Blazer is a 4WD. I've been talking about the S10.
You can either run a single 3" pipe down the passenger side, or cross the driver's side exhaust to the right side, right behind the trans and run both pipes through either a single muffler or dual mufflers. Both Summit and Jegs have such a kit to fit the Hedman shorty's. I used to have that setup. Again, you will have problem with manual trans. You will probably end up with some kind of stock cast exhaust manifolds with a manual trans (Camaro of some year I believe works - Google is your friend) and can run things down the passenger side the same way but will need some custom work. I emplore you to not do side pipes on a S10. People laugh at them.
Problem with multiple core radiators is that they get thicker and give less clearance. If you are going to retain A/C then you need to figure out where the condenser will go before you fit a radiator and you will probably best retain the clutch type belt driven fan. I think the Jags that Run book addresses that.
  #19 (permalink)
Old 06-26-2018, 12:27 PM
I don't care about side pipes either but I know with a 5 speed it is going to be hard to do I been looking for headers they fit automatic only I will have to call and find out
  #20 (permalink)
Old 07-01-2018, 11:37 AM
I once ran side pipes on a 86 s10 2wd and it was a pain to hook up exhaust to them with full length headers and I ended up having holes cut in the fame to get the exhaust through to hook them up. After many burnt legs and hated having the holes in the frame they were removed and the frame welded back up and never used again. They can be made to work better then what I had them setup as but to me it was more trouble then what they were worth.
  #21 (permalink)
Old 08-27-2018, 11:16 AM
I've got a 97 S-10 with an L31 Vortec block 350. Im running an NV3500 5 speed transmission. Exhaust isnt that big of a deal with this transmission.
Im running the Trans Dapt engine brackets with the 2.8 mounts. The Trans dapt brackets give you the option of mounting the engine raised up about an inch and a half to give extra oil pan clearance or in the stock position.
I recently lowered my engine down from the raised position to the stock position. My oil pan still clears no problem and I have a ton more clearance from the firewall and trans tunnel for the header collectors and the distributor.
The NV3500 does sit very close to the passenger side lower control arm mount with the engine in the lower position. Right next to where the clutch release cylinder goes. Had to heat up the mount with a torch and bend it out of the way.
I'm running dual mandrel bent 2.5" exhaust with two 3" chambered mufflers. Ran both pipes down the passenger side away from the fuel tank and over the axle.
S10 V8 swap motor mounts Ed A Hotrodding Basics 3 04-30-2018 09:11 AM
96 S10 v8 motor mounts Isaiah_13 Hotrodding Basics 6 01-16-2015 11:02 AM
S10 V8 Motor Mounts callmej75 Engine 9 04-09-2011 03:43 PM
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 10:52 AM
34 ford on s10 frame motor mounts jaxhome Engine 2 04-03-2005 11:15 PM
