Thanks for the link. I found that the clam shell style mounts work so i ordered some and got some poly inserts. I also got the Trans Dapt kit for the frame as some guys fromn the S10 forum recommended that. I should have lots of room because I got the forward mounted corvette radiator with dual SPAL fans with the controller. I need to look into that trans crossmember for the dual exhaust set up for the long tube hedmans.
