S10 V8 Motor Mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2011, 10:18 AM
Daily Grinder
S10 V8 Motor Mounts
Needing a little help on what motor mounts to get for the 383 swap into the S10. It's a 93' and has the 2.5 in it. I heard the 2.8 mounts and swap motor mounts will not work with full length Hedman Headers. Does anyone have a clue as to what does work? All I see is the conversion mounts for the 2.8 style stuff and shorty headers.
Old 04-06-2011, 11:03 AM
s10 swap
my son was gonna do one of those swaps. he had a book that told all the in's and out's. maybe your library has it, or the parts store.
in my experience it is always best to buy a swap kit with headers etc from the same manufacturer. that way it all fits. usually just as cheap as parting it all seperately, but i think the book was good at saying what parts to use from which odd vehicle. there is also a dedicated site for v8 s10 swaps.
good luck and don't forget to install a holy crap handle for the passenger.
keep us posted
dsraven
Old 04-06-2011, 11:20 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Check the link. Scroll down to #17
Rich
http://www.s10forum.com/forum/f10/35...itting-412959/
Old 04-06-2011, 06:42 PM
Daily Grinder
Thanks for the link. I found that the clam shell style mounts work so i ordered some and got some poly inserts. I also got the Trans Dapt kit for the frame as some guys fromn the S10 forum recommended that. I should have lots of room because I got the forward mounted corvette radiator with dual SPAL fans with the controller. I need to look into that trans crossmember for the dual exhaust set up for the long tube hedmans.
Old 04-06-2011, 06:44 PM
Daily Grinder
keep us posted
dsraven
I believe they have them books on the site...jagsthatrun? They are dedicated to S10-S15 truck and blazer swaps. I just dumped over 5 G's on the motor...so i believe that handle will be used quite frequently!
Old 04-06-2011, 07:09 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
As I have said on here before, let NOTHING get in the way of fitting long-tube headers to your motor. Whatever is in the way, cut it out with a torch, Sawzall, nibbler or hammer and chisel, then rebuild the component after the headers are in place.
Thanks for the link Richard. One fellow on there said his long-tubes had one primary tube that was rubbing on the upper control arm and that he was changing to shortys. This guy has lost his mind. He just needs to clearance the arm for the tube. This ain't rocket surgery. Shorties are only slightly better than cast iron log manifolds.
Old 04-06-2011, 07:14 PM
Daily Grinder
I agree tech...what ever needs clearancing...trust me...I got my bfh ready.
Old 04-07-2011, 09:07 AM
ive got a v8 s10 blazer and yes if u have it in the forward position u will have plenty of room all around the dist. have to run a short water pump ive got the short headers just dont get the two piece ones long tube they shoot out into the wheel wells and u will have tire rubbing any questions let me know or the s10 forum also if u can get people to reply thats my trouble on there if ur not there every day chatting every day they tend not to respond
Old 04-07-2011, 12:12 PM
Daily Grinder
I have gotta serpentine setup I'm gonna run with a short pump and a Mercruiser pulley. I am a member of the V8S10.org site and those guys tend to answer quite frequently...smaller group but the guys are knowledgable there and no BS to deal with ...thanks man and i figure I'll be shooting some PM's your way sometime!
Old 04-09-2011, 02:43 PM
I fabbed motor mounts myself. Comes out that the motor mounts need to be about three inches back on the motor from stock. I'll try to take pictures soon.
motor mounts ziggy57 Engine 2 09-20-2009 01:02 PM
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 09:52 AM
Motor mounts sanman Engine 1 01-15-2008 06:07 AM
motor mounts el Engine 3 12-24-2003 09:20 AM
Need Help. Motor mounts, SBC Ted655 Engine 6 09-21-2002 05:41 PM
