S10 V8 swap motor mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2018, 09:47 AM
Ed A's Avatar
I've started a project where I'm putting my '54 Chevy truck body on an S10 4x4 frame and installing a sb 350. After researching motor mounts I'm having a hard time getting a definitive answer on what mounts to use. Do anyone have any info? Thanks for your help.
Old 04-27-2018, 10:36 AM
Since your using a 4x4 frame you will need mounts that are for a 4 wheel drive frame as the 2wd ones will not work very well on them especially for moving things around. I have a 2wd chevy s10 with a v8 and there are even a few options for different mounts. I use the 2.8 v6 mounts and I don't know if they would really work well with a 4x4 or not as I don't think they would.
I know that on some of the s10's that was a 4x4 you would want the mounts that would be for a 4.3 v6 that was on a 4x4 and the 4.3 is basically the same as a v8 minus the two front cylinders and most things would bolt right in. That is about as much as I know for that. I know there are a few other members here that have chevy s10's with v8's in them but I don't know if any are 4 wheel drive.
Old 04-27-2018, 10:39 AM
I use the transdapt ones for my truck and they have been excellent for me and the ones below is for a 4 wheel drive swap and should be what your looking for. You can also get them from summit or jegs as well as I don't know what the price difference would be.
https://s10v8.com/s10-v8-conversion-...on-mounts.html
The Following User Says Thank You to eric32 For This Useful Post:
Ed A (04-30-2018)
Old 04-30-2018, 09:11 AM
Ed A's Avatar
motor mounts, s10 v8 swap, small block chevy
96 S10 v8 motor mounts Isaiah_13 Hotrodding Basics 6 01-16-2015 11:02 AM
s10 v8 swap mounts? MrPhotographer06 General Rodding Tech 8 07-07-2011 08:12 PM
S10 V8 Motor Mounts callmej75 Engine 9 04-09-2011 03:43 PM
34 ford on s10 frame motor mounts jaxhome Engine 2 04-03-2005 11:15 PM
motor swap mounts for a pontiac?.... PonchoTA79400 Engine 3 07-23-2004 07:06 AM
