sb chevy rams horn exhaust manifolds - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2005, 03:19 PM
NorthStar's Avatar
Will rams horn exhaust manifolds clear a passenger side dipstick tube?
I can buy some new ones for about $130 per side, they would flow pretty good and I wouldnt have to worry about leaks.
Old 07-22-2005, 04:05 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Where are you getting yours?
Check out this site. From what I heard its the same ones.
http://www.actionsalvage.com/exhaust...let_school.asp
I found some 2 1/4 center dump for $100 for both but Im holding out for some 2 1/2 center dump. I may use them for now and upgrade later.
Old 07-22-2005, 04:06 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Id say they would.
Most exhuast clear the dipstick tube no moatter what side there on. Id say it would. Anyone else? Hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 07-22-2005, 05:51 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
dipstick tube
The dipsticks come up in the same place. Drivers side is short and goes in by head. Passenger is longer and goes in by oil pan. The tube can be bent a little for final fitting. I would check around. 130 for rams horns is steep. Most people are throwing them away for headers.
Old 07-22-2005, 06:03 PM
I use them..........and have them coated. The photo is the drivers side but mine clear the oil stick on the passenger side.
MOST of the street rods I see have ram horn exhaust. Brackateer's friends are throwing them away...... ( Racers ) ....mine are using them and having them coated.......
Headers are better for the track........and I agree with Brackateer.....$130 per side is a little high. I never pay more than $15 to $20 for a Ram Horn exhaust manifold (used) . ....less if the studs are broken/missing
Old 07-22-2005, 07:53 PM
MI2600's Avatar
Member# 3287
I think he's talking about the 2 1/2" new ones that you can buy. I thought they sold for about $110 each. Check Scoggin-Dickey.
If not, that price is waaaayyy too much! I'll sell them for $129.99. LOL.
Old 07-22-2005, 08:56 PM
NorthStar's Avatar
Thanks you guys. Man does that thing run close to the block, picture is worth a lot.
I think I may have found a set for less than $130 each. I can save a penny.
Old 07-23-2005, 12:15 AM
71 c-10's Avatar
just a kid and his truck
since were talking about rams horn manifolds i have a set off my 71 c-10 center dump, you tell me where to measure and i'll tell you what size and maybe we can make a deal for cheap and you pay for S&H, there great and don't leak and im sure i have all the studs and maybe even the nuts. pm me if your interested.
**I apologize if im breaking a rule, just delete my post if i am**
Old 07-24-2005, 04:41 PM
There are different styles of rams horn manifold, but they all will clear the in block dipstick, either side. There are some dip sticks installed in the oil pan and you may need to do some engineer bending if you have one of those minority motors. Scoggins-Dickey offers the straight down 2 1/2" dumps as Corvette replacement and they were $104 each the last time I looked. Probably the best deal you can find!!! Duce's manifold is from most truck motors and are superb for close quarters. To my knowledge, they were only the 2" dump version. If I'm wrong, hope someone can post the parts/casting numbers so I can go shopping. If you are looking for a used pair, look at the passenger side closely because they were very crack prone due to the heat riser and if you do use these, throw the heat riser away!!!
Trees
Old 07-24-2005, 05:00 PM
MI2600's Avatar
Member# 3287
Yes, those turned-back style manifolds were only in the 2" variety. You can find them for both sides. They came on trucks and Novas.
The change from 2" to 2 1/2" is like night and day, but the 2 1/2" are only straight down style.
Old 07-24-2005, 05:52 PM
check out ebay
Old 07-25-2005, 10:50 PM
Corvette Exhaust Manifolds
3797901 Left
3814970 Right
I saw some at www.partsamerica.com under the Motormite or Dorman brands, but I have not heard anything about their quality. Search was for '65 Corvette w/327.
sb chevy chevelleracer2002 Engine 9 08-23-2008 07:36 PM
Wire Looms for 350 HEI with rams horn manifolds Jag Daddy Engine 8 03-17-2003 07:25 AM
Exhaust manifolds tom_scott Engine 8 03-11-2003 04:42 PM
Best Chevy SB Heads dirtlmfan Engine 2 09-16-2002 04:14 PM
Chevy SB to Olds BB conversion McSweene Engine 2 09-05-2001 08:13 AM
