sbc 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2019, 09:18 AM
sbc 383
Hi everyone was wondering if i could get some cam help. Sbc 383 scat assembly 5cc pistons 6 inch rods AFR 220 heads race ready 65cc chambers. victor jr intake #2975 holley 850 dp carb compression is 11.1 Its 1984 hurst olds weighs about 3500 pds 200r4 art carr 750hp rated trans in it with trans brake 410 rear end. Running drag radial tire.
Old 06-10-2019, 09:35 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Jones Cams
Old 06-10-2019, 12:37 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
What fuel?
Old 06-10-2019, 12:41 PM
pump gas but 108 is do able
Old 06-10-2019, 01:02 PM
ericnova72's Avatar
More for Less Racer
You want a drag race cam, a very serious street /strip cam, a hot street driver cam??
Solid roller, solid flat tappet, hydraulic roller??
With that list of parts I'm not even going to consider a hydraulic flat tappet :rolleyes.
Maximum rpm you plan to turn it??
RPM you want power peak to occur at??
Old 06-10-2019, 01:12 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Moved from Introductions to the Engine forum.
Semper Fi
Old 06-10-2019, 01:23 PM
Im looking for solid roller. Its street strip kinda thing not wanting to max rev over 6700 rpm. The heads are AFR 220 part 1065 says they have 700 lift solid roller spring setup not that im going that high but somthing 600 range.
Old 06-10-2019, 01:36 PM
ohh yeah its 2800 to 3200 converter non lockup
Old 06-10-2019, 01:55 PM
ericnova72's Avatar
More for Less Racer
Mike Jones/Jones Cams or Bullet Cams if you want a custom fit.
If I was just picking from a catalog, I would thing something around:
250/254 @.050" intake and 254-258 @.050 exhaust with .660-.600" lift, 108-110 lobe separation. Heads don't need a lot of duration split, just 2-4 between intake and exhaust duration numbers.
I'd run a 1.6 intake/1.5 exhaust rocker to push intake lift up even more with those heads. Don't need a bunch of exhaust lift, exhaust port is good and exhaust gas is easily blown out.
Just saw you stall converter info posted, Your converter is on the tight side rpm wise, so I'd stay on the low end of that duration range, maybe even upper 240's for intake [email protected]".
