SBC Damper - Timing Tab - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2013, 08:00 PM
WICruiser's Avatar
I have a 400 SBC that I am building up with a fair number of new parts.
The short block was together when I received it but I am fairly sure it is put together correctly. It came with a chrome timing cover that I believe came from Summit (can confirm if it matters).
I installed a new Summit 8" damper using the oven heating method and all seemed to go together pretty nice.
Problem is when I try to install the timing tab it overlaps the entire width of the damper so that the timing indications on the forward edge are beyond the damper and you can not see the marks on the damper.
It seems all the SBC timing indicators extend the same amount.
Does this mean I have the damper installed incorrectly?
Any insight would be appreciated.
Old 06-11-2013, 12:38 AM
68NovaSS's Avatar
Super Moderator
Wiki Edits: 9
If the timing tab is a bolt on, get a smaller/shorter one. Otherwise verify the damper is the right one for that motor.
Semper Fi
Old 06-11-2013, 09:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You might try adding a TDC mark down the front of the damper. Or as said, trim the tab you have.
A couple pages that may be useful:
Determining TDC
Differences in SBC timing tabs and damper TDC lines
Install damper
Make a timing tape
Good luck.
Old 06-11-2013, 09:36 AM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
Are you using a 400 balancer as they are different..external balance and different size.
Old 06-11-2013, 10:42 AM
I had the same problem with mine and most timing tabs go out to far as the chrome ones go so I just took mine and cut it short and made a v grove where the tdc location is and now when I use my timing light I put a mark of paint across the timing degree line I looking for on the balancer and look for the line when setting timing.
The Following User Says Thank You to eric32 For This Useful Post:
WICruiser (06-11-2013)
Old 06-11-2013, 05:01 PM
WICruiser's Avatar
Thank for the feedback.
Yes it is a 400 balancer.
Sounds like this is not a new problem so I will make it work. The damper has degree markings so all I really need is the ability to see the damper markings when aligned with the "0" mark on the indicator.
Old 06-11-2013, 08:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the damper is degreed you need only to make (or buy) a rigid pointer attached to the front of the engine. Align it to the damper TDC line w/cylinder #1 at TDC on compression stroke and you're set.
No timing tab... fastnloud Hotrodding Basics 8 04-16-2013 03:37 AM
283 SBC timing tab reading... normal?? Sin7 Engine 6 01-12-2012 08:14 PM
harmonic damper doesn't matich with timing tab? 0pyders Engine 5 03-27-2011 05:18 AM
Does anyone make a 12:00 timing tab for SBC TNshadetree Engine 7 02-04-2010 09:44 PM
SBC Timing indexing a unmarked 4.25 blower hub and custom tab 614streets Engine 9 06-14-2003 04:26 PM
