Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Engine (https://www.hotrodders.com/forum/engine/)
-   -   SBC new style crank in old style block (https://www.hotrodders.com/forum/sbc-new-style-crank-old-style-block-98422.html)
McDeuce 09-18-2006 02:25 PM
I found out the 2 bolt main 1996 pickup block I bought is cracked.
:smash:
I bought a 3970010 4-bolt main block this weekend at a swap meet and will be taking it to the machine shop to have them check it out.
My question is, if the crank from the 1996 one-piece rear seal block is good, can I use it with the older style 2-piece rear seal block? I don't have both blocks in my garage to compare. If it won't fit right in, is there an adapter?
CNC BLOCKS NE 09-18-2006 02:32 PM
No that can't be done if you had a eairly crank and a late block that can be done as we build quite a few engines using these later blocks and older cranks but you have to use a speicial rear seal adp. as we use the earlier oil pans.
To bad your combo wasn't the other way around. :smash:
Mustangsaly 09-19-2006 07:08 AM
bump ttt
let us know how it turns out..............
Mustangsaly
