Sponsored Links | |||
It's supposed to be for a short water pump. It's all the way back against the block mounted to the lower two accessory bolt holes so I don't think it can be mounted back any further. The way it sits now, it's exactly one groove out. I found an offset pulley from cvf racing that will work, but they want $80 just for the pulley. Anyone have a good resource for pulleys that might be a better value? I'm thinking like half that much would be more like it. I might just get a double groove ps pulley and run it with a blank v on the outside.
Played this game before with the race car. Went to a low mount power steering pump and the old pulley didn't line up. Scrounged around the yard and stole the pulley of of our broken 80 v6 firebird. When you install the pulley on the pump you can stop when it lines up. Course that's not a pretty billet solution. I don't know if Speedway motors has any. But there are lots of different offset OEM pulleys.
Sent from my XT1096 using Tapatalk |
Need a better pic of the power steering bracket.
Might be the wrong one. |
I enclosed a picture of my P.S. pump set up with short water pump. The pulleys appear to be the at the same locations as yours. I used a Type II P.S. Pump from Speedway with a 1/2" thick mount bracket that bolts to the head.
My 2 cents
Bought my El Co with air, power steering on the old V belt system. It was a frankenstein of brackets pieced together. It has a Vintage Air unit system. Called Vintage air and bought the whole kit for my car for like 225.00. Laser cut and works perfect. Pics...
** These brackets are actually for Camel Hump heads that I thought I was going to go with but went with Vortecs. They do have them for Vortec or bolt to the front of the heads. However these worked well. They bolt to the pump and the sides of the exhaust port bolts. I like these better as you can see the heads better. I called Vintage after changing to the Vortecs. Asked if these that were for the older no bolt front heads would work. They said they did not know if they would work with the Vortecs. So I told them I would mock it up and do some Research for them. Said I would send pics for a T shirt if they worked. LOL! Got a T shirt in the mail! Last edited by arnoldsel; 03-11-2018 at 07:33 PM. |
Those look nice. I will check them out. Part of the reason I went with the short water pump was because I have a cool old cast iron alternator bracket from an old truck. I wanted to use it on this project so here I am. I am thinking about going with a 3 groove crank pulley and a 2 groove alternator pulley. That will give me the length on the crank to reach straight to the power steering pump with a short belt. I can also run 2 belts on the alternator and there won't be any any empty v's.
This is the ps bracket that I bought. It says will work with a short water pump. https://rover.ebay.com/rover/0/0/0?m...2F272865039788 |
Vintage Kit
Recent Engine posts with photos |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Power steering pump pulley SBC | 383SBC | Hotrodding Basics | 6 | 03-07-2013 06:48 AM |
Power Steering Pulley, SBC | Sinister | Engine | 2 | 06-23-2010 08:10 PM |
power steering pulley question | yragat | Engine | 12 | 04-07-2009 07:48 PM |
90s SBC Power Steering Pump pulley Removal Help | Mustangsaly | Engine | 12 | 10-08-2006 07:00 PM |
power steering pulley | warlok | Engine | 3 | 02-11-2004 09:50 AM |
