SBC sparking on 5 cylinders only. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2019, 09:51 AM
Hey guys and gals, my sbc 350 is absolutely driving me into the looney ward. Ive been dealing with a progressive no-spark problem for months. With previous dizzy engine would run very rough and die. Dropped in a HEI DUI unit and engine would crank, try to start -- but no dice.
Then it would crank only. No spark in any cylinder except for a very weak spark in #4. Pulled #1 plug and it was black with soot from cranking and stumbling I suppose ; unusual on a new set of Iridium plugs.
I installed a new ignition module and no difference. Pulled the DUI unit and replaced it with a good, standard HEI and got it to run, although badly. It was obviously dropping cylinders.
Checked spark and it's sparking on cylinders 1-3-5-7 (left bank), and only #4 on the right bank.
It has new wires, and there's no mix-up. Cap and rotor look fine.
The winning answer gets a 24-pack of your choice of beer. Really!
Old 07-15-2019, 09:59 AM
First thing to do is to check the voltages going into the ignition system. If undervolt you will get a lot of what you are seeing.
Bogie
Old 07-15-2019, 10:12 AM
Yes, Bogie ... paramount. I checked the voltage along the way using the ohm meter, and it registered a solid 12v at the ignition and dizzy, and 10v when cranking. However, I will check it again for sure; it hasn't been checked lately.
Old 07-15-2019, 10:39 AM
Run a separate wire from battery + to power input on HEI. This will bypass all wiring and Ig switch. You'll need to disconnect the wire to shut down engine. Pull spark plugs and put in a set of dry properly gapped plugs. Used plugs are OK. Check spark plug wire Resistance with an ohm meter. Write down the resistance of each plug wire. You'll need the high scale of the meter around 20,000 ohms. Obviously the longer wires will have higher resistance. You're looking for wires that are way out of the range of reasonable resistance. I know you said new plug wires. Lately I've seen bad NEW plug wires. Double check plug wires are in proper firing order. When you get it running, even poorly, spray plug wires and distributor cap with water from a spray bottle like a Windex bottle. Look for spark arcing at wires or cap. Is this a new or newly rebuilt engine and possibly the valves are adjusted way to tight? Let us know what happens. Beer is good.
The Following User Says Thank You to '48 Austin For This Useful Post:
Rip VW (07-15-2019)
Old 07-15-2019, 11:04 AM
silver74vette's Avatar
Check the ground strap to the engine/ transmission. You can try grounding with jumper cables from each head to make sure you have a strong ground.
The Following User Says Thank You to silver74vette For This Useful Post:
Rip VW (07-15-2019)
Old 07-15-2019, 11:46 AM
I'll perform all of these steps eventually, and thank you. First though, I'm concerned with the lack of spark in those 3 cylinders (2-6-8). I'm checking spark of course at the boots. I will check the wire resistance, and look for spark arching while cranking. I have a 4-cylinder spark tester and it works great; showing spark on the four cylinders 1-3-5-7.
To pull and replace all the plugs is a 3-4 hour+ exercise in frustration. Because this is a 22' boat engine (in a very tight-space center console), the combination of the Vortec heads and the new Mercruiser exhaust risers, you can't even see the plugs -- must blindly reach under to find them -- and some have maybe 1/4-inch clearance. I have to use three different tools to get'm in and out.
Old 07-15-2019, 12:40 PM
Rip VW's Avatar
Last journal entry: This thread is officially Kaput as of 11/07/2017
X two from here. if it ran fine on the stand and crappy in the car Something is not right. grounds are usually the first thing forgotten when doing a engine swap.
Ground to body and chassis. 12 volts jumped from + on bat and if your dist is good and wired are good and plugs are good, Do you have Fuel to the motor? it should light off then.
Old 07-15-2019, 01:03 PM
36 sedan's Avatar
Plugs are fouled from fuel or oil, if your using them to check spark youíll probably not see it because itís grounding inside the plug.
You may have a flooding carburetor causing your problem
Old 07-15-2019, 02:10 PM
The plugs and carb are not relevant to this exercise -- only trying to get spark in cylinders 2-6-8. Spark is good on cylinders 1-3-5-7 (left bank), and only #4 on the right bank. I'm using a pro 4-plug spark tester hooked to the spark plug wire boots and a ground to the engine. No need to have engine running, just cranking.
I have verified grounds are solid.
And thanks, Rip, but the Blueprint 350 long block engine was fired up for the first time after installation about 4 months ago. Its been a nut buster ever since.
(the rest of the suggestions are top notch for when I get it running again, however badly).
Larry
Old 07-15-2019, 03:49 PM
36 sedan's Avatar
JMHO, and just trying to help, not trying to insult, disrespect or anything else, but, nothing is ill-relevant. Black sooty plugs are a symptom, just like everything else, usually black sooty is a sign of PLUGS firing a rich fuel mixture, plugs that don't fire are usually wet.
But carrying on to other things, try your spark plug tester at the cap to see if wires are grounding out, sometimes rodents chew on the spark plug wires where you can't see it (and they can do it overnight). If the tester reads the same cylinders are dead at the cap as it does on the wire ends, check your cap and rotor even if it's new. And, make sure your module is phased correctly.
The Following User Says Thank You to 36 sedan For This Useful Post:
Rip VW (07-16-2019)
Old 07-15-2019, 06:25 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Sounds like it’s something under the cap to me.
The rotor, tang, button, crossfire, tracking, something like that.
Old 07-16-2019, 05:09 AM
On the cylinders that are not running/sparking, disconnect the plug wire at the plug and plug in a known good plug and lay it on the valve cover. Check for spark with your tester and at plug gap. If you get spark, the plug in the cylinder head is badly fouled and that's why it won't run on that cylinder. Fouled plugs can be from extremely rich or flooding situation caused by closed choke or very high fuel pressure that would overpressure the float needle and seat and flood the engine with fuel. Check fuel pressure at carb. Should be about 4.5 to 5.5 PSI. Certainly no more than 6 PSI. Are you running an electric fuel pump? If so you may need a pressure regulator to get pressure down. OR a bunch of dirt may have been pumped into carb and got caught between needle and seat not allowing fuel flow to be shut off by the needle and seat therefore flooding the engine. Let us know what happens.
Old 07-16-2019, 07:59 AM
2001Blazer4x4's Avatar
Redneck Professional
Need to back away for a minute from the idea that you have no spark. How sure are you?? Enough to hold the end of the plug wire?
Really sounds like badly fouled plugs from overly rich mix to me (all the way back to the beginning of your story with original distributor).
Old 07-16-2019, 08:58 AM
Excellent ideas, especially to test spark at the cap. Once the engine eventually idles and fires on all 8, I think the sooty plug issue will go away with a new set of plugs. If not, I will check fuel delivery and pressure, adjust carb settings -- it's a rebuilt Quadrajet and could very well be running rich -- and use the advice all of you have generously given me.
And 36sedan, please never hesitate to be frank. You will never hurt my feelings when trying to help.
The Following User Says Thank You to LARRYOWEN For This Useful Post:
36 sedan (07-16-2019)
Old 07-16-2019, 10:30 AM
I love Austins! I was 6 years old when your chassis was built, and my dad said it was his most preferred auto, post WWII.
I have already tried many of your suggestions, but the plug wire resistance test I will do tomorrow. Maybe at night so I can see any arching, etc. I'm going to switch some wires #4 (with spark) and say, #2 (no spark) to see if the spark follows it. Thanks!
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
