Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Timing indexing a unmarked 4.25 blower hub and custom tab
Old 06-13-2003, 11:15 AM
gumby gumby is offline
Your timing marks are correct for a running engine.
when building a engine you install the crank mark at 12 o'clock. and the cam at 6 o'clock. But, then you turn the motor two full revolutions. This puts your marks at 12 and 12. The timing is correct. If you index from this point you should be right on the money
michael
