Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Timing indexing a unmarked 4.25 blower hub and custom tab
Old 06-13-2003, 04:11 PM
fortyfordcoupe fortyfordcoupe is offline
Gumby if you turn it 2 revs its back in the same place! On my small blocks the cam turns half the speed of the crank, 1st full rev it would be top of exhaust stroke, 2nd back at TDC, feel sorry for you if your's doesn't do this. Sounds like its on top of exhaust stroke not TDC.
614 check number 1 on dist, that should tell. Does it run like this? if it does its right. then indicate like SC said.
