Shoe horning a SBC into a Mercedes 450 SL - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-16-2018, 12:01 AM
Originally Posted by OneMoreTime View Post
Looks to me that a Small block ford may be a better choice in that car..
Sam
Or a modernish 4 cylinder running 10-16psi using mega squirt or other standalone.
  #17 (permalink)
Old 11-16-2018, 06:42 AM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Apparently, Joe has zero interest in what any of us think, he was looking specifically for someone who had done a Gen I swap into a 450SL. I doubt that we'll ever hear from him again. Not to worry, there are thousands of other fellows who will appreciate our knowledge.
  #18 (permalink)
Old 11-16-2018, 10:42 AM
Too bad, there are several versions of these things that are similar but not exactly identical in dimensions so he will eventually learn that there is no precise dimensional recepie that fits every build. Space is critical how it gets built dimensionally as mods proceed will drive the fine modifications needed for installation, you just can't get beyond generalizations because of that. The info he was given is more than adaquate to get started, probably the one thing missing is that there is great aid in using plastic mock ups of the Chevy engine and transmission since they are light and dimensionally correct that a person can maneuver them about to get the needed dimensions, but it's a substantial added cost to the build.
Bogie
The Following 2 Users Say Thank You to BogiesAnnex1 For This Useful Post:
AutoGear (11-16-2018), techinspector1 (11-16-2018)
  #19 (permalink)
Old 11-16-2018, 09:11 PM
Bogie
That is why I make mine out of cardboard or plywood whatever is laying around the shop. If you have the engine on the floor you can simply trace the rear profile, make another for the front, then measure the blocks length and use the threaded rod/nuts to make your mock up block bolting it right to the bell housing.
The pictures on the Chevy link I linked earlier are quite accurate. Just scale it to real world scale using a free graphic program like gimp and print it off and tape the thing to your cardboard.
Sounds cheap cause it is. Cost of threaded rod/nuts and maybe another $10 in paper and cardboard.
Cheap, light, and when your done does not take up any shop space. It works good enough to say hold a oil pan or header up to the mock up block and get a very good idea the real clearance you have.
1995 Ford T Bird rear pumpkin into 1984 380 SL? swingnut Transmission - Rearend 2 08-03-2014 05:31 PM
Is this site SL-O-O-W nowadays??? Irelands child Hotrodders Site Suggestions and Help 46 04-28-2012 08:35 PM
Olds Ciera SL Spark Coil... awbazar Electrical 2 09-03-2010 04:11 PM
Finally found CI4/SL oil Don Meyer Hotrodding Basics 7 03-16-2009 11:12 PM
where to buy SL oil Don Meyer Hotrodding Basics 24 09-28-2008 10:43 AM
