Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show me your home made tools so I can copy them!
Old 09-11-2009, 07:43 AM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Very inventive.
Originally Posted by S10xGN
Here are 2 that I made, the first is a "hole saw" for nylon carpet made from a 2" piece of 5/8" SS tubing with a washer welded to the end and a long bolt (cut off head and grind to a point) nutted tthrough the washer. I heat it up with a propane torch and use it to drill holes in carpet for seats, consoles, etc. Use the "point" to locate the saw through the carpet (into the bolt hole).
The second is a pressurized brake bleeder that uses ~ 30# of air pressure to force brake fluid through the lines, making brake bleeding a one man job. Use a large "C" clamp to hold 'er down.
Russ
Top job. By tomorrow they will be made in China. I will give you a top score on the one man brake bleeder.
Cheers
Al.
