Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show me your home made tools so I can copy them!
Old 09-11-2009, 08:23 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Sanding in tight corners.
On almost any car there will be some very tight corners that need sanding when doing your paint prep. I made this little tool for getting into those corners. It's a length of 1/8 x 1" steel, bent slightly, handle wrapped in closed cell upholstery foam, and a piece of stick-on sandpaper attached to the business end (photo 1). Photo 2 shows the tool's use in a tight corner of my pickup bed.
Always learning...and sharing what I've learned.
