Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - show me your home made tools so I can copy them!
  #17 (permalink)
Old 09-11-2009, 10:02 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Tool for sweeping bends in square tubing.
Talk about crude tools...this is the one I used for bending the ribs for the body of my roadster. The tool consists of a "form", 3/4" particle board cut to the inside shape I want the ribs. The form is then bolted to the side of the garage and a length of 1x1 tubing is then clamped to the top of the form. a come-a-long is then attached to the other end of the tubing and secured with a bolt to a garage stud. Then just crank.
Here's a shot of the "tool", a bunch of ribs that I bent with it, and a shot of how these ribs were used to form the rear section of my '31 roadster body. More info on the bending process can be seen here.
Always learning...and sharing what I've learned.
