Show me your motor mounts!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2011, 12:29 PM
Im looking for ideas on motor mounts on my 52 chevy truck. It has Mustang II crossmember. Not sure what to do at this point. Thinking of going with biscuit mounts but not sure if theres room for steering. Any ideas or pictures?? Thanks
Old 02-10-2011, 01:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Speedway sells a front-mounted motor mount plate that frees up the sides of the engine:
They also have other mounts, etc.
Old 02-10-2011, 01:38 PM
machinist & fabricator
USE THIS MOUNT!!! cant beat it for 60 bucks @ speedwaymotors.com
just make sure you use bolts w/ cottor pins
Old 02-10-2011, 03:36 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Man, I'm seeing double and hearing an echo....
Old 02-10-2011, 04:22 PM
ogre's Avatar
the 'Duracell Project'
these are in a 58 chevy truk with a fatman mustII, it might give you ideas
Old 02-11-2011, 07:12 AM
52 chevy motor mounts
I've got a 1950 3100 and thought I would have the same problem.Went with tight tuck headers.Loosened up alot of room.I also seen one where the guy cut a hole in the firewall to move his column over about an inch.IDIDIT has alot of adjustable steering options.
Old 02-11-2011, 08:16 AM
Wiki Edits: 49
I used biscuit mounts with the hemi in my '53. It has a Heidts Mustang II IFS, power rack with a modified GM pump and there were no problems with routing the steering shaft. You should have plenty of room especially if you're sticking in something smaller than a hemi.
As you can see the hemi filled the engine compartment to the brim. Any steering interference you will run into will probably be from the exhaust system, not biscuit motor mounts.
Centerline
HotRodsAndHemis.com
"Aerodynamics are for people who canít build engines." Ė Enzo Ferrari
Old 02-11-2011, 09:38 AM
OLNOLAN's Avatar
Homemade Mounts
Hey JJ, These are photos of homemade mounts and did for my '57 3100. I had everything I needed in my shop junk, cost= $0.00. The engine mount bars are 2x2 trailer hitch receiver bar tubing, 2x3 angle, used shock bushings for late model GM truck. The transmission crossmember is 1 1/2 x 1 1/2 tubing. Just to give you some ideas. olnolan
ID:	52605   Click image for larger version
ID:	52606   Click image for larger version
ID:	52607   Click image for larger version
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 09:52 AM
motor mounts racur96 Engine 1 01-21-2004 10:30 PM
motor mounts robbysapien Engine 9 10-30-2003 04:03 PM
LT-1 and LS-1 motor mounts acourtjester Engine 1 12-30-2002 02:25 PM
Motor Mounts MHenricks Engine 4 10-10-2002 06:42 AM
