Single piston caliper vs Dual piston caliper - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-03-2019, 01:42 PM
RWENUTS's Avatar
Originally Posted by tools View Post
Just checked with speedway the pedal ratio is 6:1 , it's a universal fit part .
Drill a new hole an inch to an inch and a half lower on the pedal to get to 4.5 to 1.
6 to 1 is for manual brakes.
The Following User Says Thank You to RWENUTS For This Useful Post:
tools (05-03-2019)
  #17 (permalink)
Old 05-03-2019, 02:22 PM
tools's Avatar
The way the pedal is if I drill a hole lower, the clevis on the brake booster shaft will push it slightly up into the booster diaphragm . Right now it is straight and the pedal feel is good. By moving the hole lower to get the 4.5:1 ratio will I be getting a longer travel on the brake push rod ?
  #18 (permalink)
Old 05-03-2019, 03:54 PM
ericnova72's Avatar
More for Less Racer
Lowering the hole will decrease the amount of force you are putting into the master cylinder....the exact opposite of what you want to be doing.
If you can't lock the front rotors, pedal ratio isn't the big problem at 6-1 ratio....you're either not making enough pressure from the master or have a pad/rotor friction problem.
Even manual brakes should be capable of locking the front rotors, no problem.
The Following User Says Thank You to ericnova72 For This Useful Post:
tools (05-03-2019)
  #19 (permalink)
Old 05-03-2019, 03:59 PM
RWENUTS's Avatar
Yes you will and getting longer travel inside your m/c which will give you better stopping force.
tools (05-03-2019)
  #20 (permalink)
Old 05-03-2019, 06:33 PM
55 Tony's Avatar
And it will be harder to push the pedal.
Young enough to learn ... too old to remember.
The Following User Says Thank You to 55 Tony For This Useful Post:
tools (05-04-2019)
  #21 (permalink)
Old 05-03-2019, 06:44 PM
ericnova72's Avatar
More for Less Racer
The only way this would actually matter is if the pedal is hitting the floor before the master cylinder if fully stroked.
If he can fully depress the pedal, without the pedal hitting the floor, and not lock up the front rotors the pedal ratio is not the problem.
tools (05-04-2019)
  #22 (permalink)
Old 05-03-2019, 06:46 PM
RWENUTS's Avatar
Thatís what the booster is for.
Reduces that needed action.
tools (05-04-2019)
  #23 (permalink)
Old 05-03-2019, 06:48 PM
RWENUTS's Avatar
Perhaps, but 20 minutes with a drill will decide that.
Maybe he needs some residual check valves.
tools (05-04-2019)
Which Type Piston to use Hypereutectic or Forged LenB Engine 8 07-02-2016 12:03 PM
Blazer dual piston setup Vs. SSBC dual piston calipers! veltboy314 Suspension - Brakes - Steering 1 11-28-2010 06:37 AM
1963 Impala single Master Cyl. to Dual MC? impalaman63 Suspension - Brakes - Steering 6 06-24-2010 04:13 PM
single plane intake vs dual plane cuda66 Engine 5 03-04-2003 02:03 PM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-06-2003 11:56 PM
