Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Skip White Heads BBC
  #98 (permalink)
Old 04-24-2019, 06:05 AM
55 Tony's Avatar
55 Tony 55 Tony is offline
Originally Posted by techinspector1 View Post
For a street driver, the tallest dual plane you can find is going to make the most power in a range that is useful. The longer runners have proven to be the answer for motors that are used up to about 6000 rpm's. Chrysler Corporation engineers experimented with some off-the-wall intake manifolds in the late '50's, early '60's, like the ram induction two-4 barrel unit. It was a cross-ram with the left bank carburetor sitting above the right bank valve cover and the right bank carburetor sitting over the left bank valve cover. It was the longer runners that made the best power.
https://www.pinterest.com/pin/84864774207681420/
If I had to buy an intake manifold for you, it would be an Edelbrock 7164, Chevrolet Performance 12363420 or Professional Products 53001 (carb pad height 5.750")..
I bought the Edelbrock 7164, but according to Edelbrock, it's not much different than the one I had, the performer 2-0. It sits about 1/2" taller with the plenum about 1/2" further down than my old one.
Don't know if I'll end up with a 4 hole spacer or an open one.
Young enough to learn ... too old to remember.
